It is currently Mon Jul 21, 2025 1:22 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri May 23, 2014 6:32 pm
I wonder if Liquid Intelligence 115 is the same as Evans Waterless?
They seem to have a huge range of products but the 115 is the waterless.
http://liquidintelligence115.com.au/
PostPosted: Fri May 23, 2014 6:35 pm
Thank you for the input from everyone.
Is there someone personally who has used it?
66 MK 1 Cooper S
64 Grp N Cooper S
64 Grp N Cooper S (ex Bob Asher)
64 GRP N Cooper S (ex Fred Burley)
PostPosted: Sat May 24, 2014 7:57 am
Oh dear, worry, worry...
HI Freddo
I use it in my race car, when i did a shake down run with my race car i did a meeting at the short circuit at eastern creek i hand a problem with the fan belt jumping off at high rpm but i could do four laps flat out before the temp would get up to 240 deg f then i would come in take the radiator cap off let it cool down and off we would go for the next race, had this been water or coolant in it the motor would have locked up.
There is a draw back with it, it takes a little longer to heat up but not much but it also takes longer than water to cool down, as in traffic if it got hot it would take longer to cool down once you got moving, the MAIN THING to be care full of is the radiator it self if the core is too fine(where the coolant flows through) not the air the water less coolant will not flow through the cores because it is a lot thicker than water but the water pump will let you know as it will push all the coolant out the over flow other than that i find it very good as in if your sitting on the grid or in your case traffic you don't have to worry about the motor over heating and pushing the water out as the boiling point is 300deg f hope this helps.
Graham Russell
PostPosted: Sat May 24, 2014 9:56 am
Very helpful Graham. Thank you :D
66 MK 1 Cooper S
64 Grp N Cooper S
PostPosted: Sat May 24, 2014 10:16 am
just on rads....I have heard very good reports about Silver Seal in older engines...used as insurance for the inevitable crack or pinhole...anyone?
http://www.silver-seal.com/category/sho ... nd_repair/
PostPosted: Sat May 24, 2014 6:42 pm
You have probably seen this but it is quite good.
https://www.youtube.com/watch?v=VkNz-ANfUkc
PostPosted: Wed Jun 04, 2014 10:31 am
I stand by Home brand ground white pepper.
It's easy once you know how.
PostPosted: Wed Jun 04, 2014 10:35 am
cheapskate :lol:
