It is currently Wed Jul 23, 2025 1:42 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Nov 12, 2013 2:16 pm
The UK 2 core is more robust. The cheaper UK 3 core is very flimsy, mine lasted 3 weeks before the side strips parted company with the top join (which is poorly spot welded not rivetted like most radiators). I soldered it back together and sold it.
I put a Minispares/Karcraft super 2 core in Barney years ago, AFAIK it's still in there. They are a good radiator if you need a new one.
I'm convinced on the 2 core one now. It might help to "future proof" the cooling system for any further modifications down the track. And $230 for a really good radiator is a lot cheaper than a rebuild after cooking the engine.
Convertible Mini wrote:
So much for "QUICK" questions....
I did say a few...
Wombat wrote:
TheMiniMan posted how to remove/replace the radiator the easy way some years back haven't checked to see if it is in the how too section or if anyone can find it or maybe Matt will post it again.
PS found it - two versions - Matts is the second one (scroll down)
http://www.ausmini.com/forums/viewtopic.php?f=25&t=11224
That seems like an easier way to do it than I did. I might have to give it a go getting it back in.
pattiley wrote:
pattiley wrote:
With all those bent fins you will have lost about 20-30% of your cooling efficiency. You can gently straighten them with tweezers or a custom bent paper clip
You can do it faster and safer with a bit of plastic card, such as used for spreading bog.
Yeah if they're not too bad you can use a pet comb as well
I might give it a straighten up and then keep it stored as a spare. Should I keep it dry or is it best to put something in it?
PostPosted: Tue Nov 12, 2013 6:22 pm
It's OK to keep reconditioned ones dry.
If it's pretty clean inside I would run radiator cleaner through it before you take it out, then store it dry too. But some folks do fill them with water for storage.
PostPosted: Sun Nov 17, 2013 8:39 am
I did run some cleaner through it before I removed it so it should be good then thanks!
The vacuum advance line from the carby to the distributor had what I assume is a one way valve in it. The line must have been a bit fragile because it broke when I moved it to the side to change the thermostat housing etc.
Do I need a metal line with the valve or can I just use a bit of rubber vacuum line?
PostPosted: Mon Nov 18, 2013 11:21 am
It would seem according to minispares that the metal one with the vacuum chamber is not needed anymore. I assume then that a simple rubber vacuum line would be fine to use
http://www.minispares.com/product/Class ... o%20search
PostPosted: Wed Oct 08, 2014 8:24 am
New question: these two nuts are completely loose and about to fall off. Should I have noticed something different happening to the clutch recently?
PostPosted: Wed Oct 08, 2014 1:39 pm
Tim , you don't need the nuts throw them away.
PostPosted: Wed Oct 08, 2014 8:07 pm
They're a little bit of a leftover, with their actual purpose lost in time...
I haven't had these on my mini for a very long time. They once used to prevent over extension of the clutch which lead to damage, but it seems these days that:
1. Mini clutches slave cylinders don't push far enough to cause damage, and/or
2. the clutch plates (at least the diaphragm type post 62) don't want to be damaged by over extension.
PostPosted: Thu Oct 09, 2014 8:05 am
Thanks guys, that's good to know :D
PostPosted: Thu Oct 09, 2014 11:46 am
If the clutch hose fails you might just need those nuts.
PostPosted: Sun Oct 12, 2014 12:59 pm
I might just tighten them up and hope for the best then. Is there a method to setting how far out they are from the clutch cover?
On another note, are all dry front subframes the same? If I bought one from a clubman would it fit my car fine?
PostPosted: Sun Oct 12, 2014 1:14 pm
Dry subframes are all the same.
PostPosted: Sun Oct 12, 2014 3:03 pm
Thanks, I've got my eye on one from a clubman and didn't want to waste my money!
PostPosted: Tue Oct 28, 2014 2:31 pm
This turned out to be a bad decision as I tightened them up pretty tight with my fingers and they wouldn't spin anymore. (I thought)
I got halfway to work this morning and then the clutch pedal was not disengaging properly. I thought I'd ruined the clutch or something and was grinding the gears at the traffic lights trying to get first gear. I stopped as soon as I could and saw that these nuts had worked their way down the thread and was preventing me from pushing the clutch in. They were promptly removed and now the car works fine. :oops:
PostPosted: Tue Oct 28, 2014 3:19 pm
Correct method is adjust the stop nuts AFTER setting the clutch arm gap to .020".
As you found, if they are too close they prevent clutch disengagement.
As said in another thread, for years I have left them off, and the return spring too. I set the clutch arm stop gap to ~1mm.
The tiny spring in the clutch slave cylinder then makes the clutch self-adjusting, like 99% of all cars built since 1980 including the Mini (with verto clutch).
I run an orange dot diaphragm, with standard 7W5-8 type release bearing, and it ain't broke yet.
As I still have a `Matic heater above it, this also saves me having to pull the grille out to adjust the clutch. :wink:
PostPosted: Tue Oct 28, 2014 10:03 pm
The correct setup and gap is outlined in the workshop manual if you do decide to put them back on. The two nuts need to be locked together tight to prevent them moving along the thread, sounds like your became loose.
As mentioned they are basically supposed to be a safety stop to prevent damage to the motor. It looks like yours were originally so far away from the clutch cover they may as well have been not there anyway.
