Mokesta wrote:
Doc, rovers have the front belts mounted in the rear companion boxes. I have a chunk out of a rover shell and I can't see and more spot welds holding it in or any other structural difference. There is a mounting bracket welded inside the box for the retractor.
That may well be so; but it was years ago, I had never seen a Rover shell and it looked dodgy as at the time. No captive nut, they just drilled a hole and stuck a bolt & nut in it.
Late Oz Clubbies have the front belt in the pocket, but it has a proper nut welded to the inner sill, which is thicker than the flimsy pocket.
