TK wrote:
Nick,
I had a 'nipple extension' off a pre rod change Moke gearbox. I'll have a look for it mate. If I find it, it's yours.
Thanks mate. That is good to know even from the point of view of confirming there is enough space to route something like that up to an easily accessible spot. I'm not after freebies so don't look too hard, I was going to visit somewhere like Pirtek this morning and waste some of their time anyway.
Nick,
How did the reclaimed one go (which I built the lower end up 1mm with nickel bronze)?
Hey Kev, your damper yoke went well. It was probably almost a little too thick and I
almost worked up the energy to change over the chucks in the lathe but I ended up needing another shim for the pinion so I had to visit my local mini guy who had a bent rack out of a wreck that he raided the shims from and now all is good. It feels pretty good now that it is all assembled and I ended up using a bit over 200mL in the rack as there was a couple of spillages when the air bubbles came up. Just working on finishing off the paint job this morning.
I ended up replacing the pinion bearings as well as although the races on the old bearings looked fine, once I assembled it and started working out shims and turning the pinion, the feel was notchy and not smooth. I tried to find the bearings locally from four bearing shops and they all remaked at how weird the were and then told me they couldn't find them. I could only track down cheap chinese bearings that don't even have a manufacturer name printed in them (seriously? the manufacturer has so little belief in their product they don't even stamp their name into them???) despite my willingness to pay for decent bearings. After talking with my local mini guy he reckoned you can't buy anything but the chinese bearings now unless you pull apart old racks and look for better bearings than what I had.
Anyway, once it was all assembled and oiled up (I bought 140 mono) it feels pretty nice. Just finishing off the paint job and replacing the bushes in the steering column while I am in this area.
^Ready for putting back in the car - reassembly is the reverse of removal. Hopefully I don't scratch too much of the paint off putting it back in the car.
^Pulled the column apart and gave it a paint.
^Hmmm, maybe this is why there was some movement in the column as well, not to mention the ID of this bush fits the column like a hotdog in a hallway.
