It is currently Mon Jul 28, 2025 3:30 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu Jun 11, 2015 4:17 pm
16E is a 12G202 head as you've said. Originally fitted to 997 Coopers and 1098 minis. It's a step above the stock 850 and 998 head with bigger valves and ports.
16F - check the valve sizes and compare against this list http://www.calverst.com/articles/ch-cyl ... _%20no.htm
16K - check the part numbers and chuck them in google. They might be STD or undersize
17 Pistons are +020 thou overbore for a 998.
17 Cam - http://www.camtechcams.com.au/mini_4cyl.html
Fair idle, good bottom end
and mid range power designed for engines with limited modifications. Min 9:1.
RPM RANGE 1500-6500
18 Cam - looks to be a standard 850/998 cam, but could be reground
18 Crank - 998 crank
19G & H - HS2 single carb air filter housing
20B - Stepped drums. Fitted to the rear of disc brake cars and all round on late cars
Anything with a part number should be able to be found in google with "mini" added to it.
PostPosted: Thu Jun 11, 2015 6:42 pm
MG Rocket wrote:
I can see 4ZR on the radio. I grew up with 4ZR.
How about 3KZ is football. Captain Blood and The Major calling a Grand Final sticks out in my memory !
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Thu Jun 11, 2015 6:49 pm
Are you looking at selling anything at the moment?
PostPosted: Thu Jun 11, 2015 7:02 pm
Lots of stuff there is worth more than you think. You did well.
"Let us remove your "SHORTS"
PostPosted: Sat Jun 13, 2015 5:58 pm
RPM RANGE 1500-6500
Thanks mate, appreciate the help. So much to take in at the moment.......
Not right now. Once I have sorted everything and figured out what I have, then I'll start selling what I don't need.
PostPosted: Sat Jun 13, 2015 6:05 pm
These pictures are extreme longshots today :!:
I'll chuck them up anyway and see what we come up with :?:
21. Wiring harness
22. Wiring harness
23. Wiring harness
24. Wiring harness
25. asst wiring, signal.
Maybe the colour of the plugs give it away?
If no luck I can chuck some other photos up.
Thanks.
PostPosted: Sat Jun 13, 2015 11:06 pm
Sometimes there may be a sticker on the harness itself with a part number. I have seen rear harness's with the sticker.
Check for this (doubtful, but may get lucky)
PostPosted: Sat Jun 13, 2015 11:16 pm
Well I think it's pretty obvious which different models those harnesses are from.
(...I'm just kidding they just look like black spaghetti...)
PostPosted: Sun Jun 14, 2015 9:35 am
25B looks like the rear tail light / boot harness. The one that plugs in at the front L/H side of the dash / parcel tray (9 pin plug next to the grommet) and runs up the A pillar and along the roof to the back of the car. Can't tell which model it's off!
I'm more familiar with late model square nose harnesses but the other main harnesses I'm guessing look like they are for round nose centre speedo binacle.
Cheers Shane
PostPosted: Sun Jun 14, 2015 9:34 pm
No luck, thanks for your input though.
Cheers Shane
Thanks Shane, was a longshot and wasn't expecting any bites. So you've done well. Cheers mate.
PostPosted: Sun Jun 14, 2015 9:43 pm
Some more ID's for now, cheers for checking these out.
26. Asst lights/lenses, models?
26F & 26C are all glass lenses......
26G I know is Clubman front blinker/parker setup. Any other models?
27. Switch panels, fuse blocks, H ignition barrel?
Thanks for looking :wink:
PostPosted: Mon Jun 15, 2015 2:12 pm
Well i know 27c is off an 850 as it has the windscreen washer pump/button on the left.
Dusk Blue
1964 850
PostPosted: Mon Jun 15, 2015 2:55 pm
26B Aux Brake Light. My 77 Leyland Mini has the exact same one fitted to the rear parcel shelf.
PostPosted: Mon Jun 15, 2015 4:08 pm
21A Wiring harness, appears to have a multi pin plug for a Clubman type dash
22A Wiring harness, looks like Mini K but I can't see enough of it.
23A Wiring harness, lots of square plugs that don't look right but I think I can see the Clubbie style dash plug but the rest of it looks late model.
24A Wiring harness, looks like a birds nest, no idea.
25A Blinker switch, early type, missing the green light on the end of the stick.
25B Rear harness
25C Looks like a radio loom.
26A Generic trailer lights that are sometimes fitted to Mokes when they can't get the right ones.
26B Generic high level brake light
26C,D,E Mini numberplate lights. Some may be Lucas and some may be copies.
26F Lucas blinker lights, also fitted to lots of other 50s and 60s British cars. Clear ones are front on a Mini, Orange ones were rear on a Moke.
26G Clubman/Leyland Mini front blinker/parking light.
27A Switch panel, I think this is from a 72 Mini van or poverty model sedan.
27B Switch panel, 72/78 Clubman/Leyland Mini.
27C Switch panel. by the colour I assume Deluxe/Cooper S/Mini K.
27D/E Switch panel, looks to have the 850 style two position ignition switch. (on/off switch)
27F Voltage regulator, suits Mini with generator, they will have a date on them.
27G Voltage regulator, Morris 1100.
27H Ignition switch, three position switch, suits Deluxe/Cooper/Cooper S/Mini K/Morris 1100/etc... (on/off/start switch)
PostPosted: Tue Jun 16, 2015 4:24 pm
Thanks MrFail & gtogreen, appreciate your help
25B Rear harness
Sensational mate, extremely grateful for your help! We need a 'Thanks' button on this forum for you.
