It is currently Sun Jul 27, 2025 2:36 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Jul 09, 2015 6:40 pm
thegimpy1972 wrote:
Hi Doc. Do you have air/fuel meter mounted in dash Or do you have a bung and use it when required?
I put the meter in a Jaycar plastic box, and mounted the sensor in a bit of 1" tube which clamps into the tailpipe. Copied off the one GR uses on his dyno.
I've now wired the 12V with both alligator clips and a cig lighter plug, so I can even run it on my Jeep.
I didn't dash mount the unit, IMO once the mixture has been sorted out it's about as useful there as a vacuum gauge... :lol:
Only down side to the tailpipe sniffer is it's useless at idle. But I hear if you shove some copper tube in it to reach up into the muffler, it'll work OK.
Pics-
PostPosted: Thu Jul 09, 2015 8:17 pm
Thankz doc for the explanation. cheers
PostPosted: Sat Jul 11, 2015 12:32 am
Put 170 mains in the weber today and the flat spot is now gone. :D
Originally I thought my flat spot was just a dizzy advance problem so I bought a dial back timing light.
In the end I had to -
Replace the blown GT40 coil with a GT40R style and put a ballast resistor in for the elec ignition. The Crane Cams people recommended the Fireball XR700 run a ballast resistor setup. Apparently these modules don't like 12v.
Changed the dizzy curve by removing a spring.
Tweeked up the weber to suit my engine.
Goes great now, Thanks everyone for the input.
