It is currently Sun Aug 10, 2025 9:01 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 231, 232, 233, 234, 235, 236, 237 ... 568  Next
PostPosted: Sat Apr 16, 2011 4:31 pm
Reco my drive shafts new cv joints , new wheel bearings roots and ebc green stuff pads ! Painted hudb and drive flanges fitted braided brake lines and fitted my reco calipers ! Car looks awesome so excited
PostPosted: Sat Apr 16, 2011 5:54 pm
Posted 2 reconditioned racks up to TheMiniMan in Brisbane. I put them each in a 150mm dia x 980mm PVC tube with end caps. Post cost only $16.05 ea, sure beats courier pricing... if sending racks to and for. :P
Just need to watch the length- Ozpost's maximum is 1050mm.
PostPosted: Sat Apr 16, 2011 6:24 pm
This weeks small job was manipulating the new extractors into the 62 Cooper. Now she's got an all new exhaust from back to front. Rubber unis take some effort to get a set of LCBs around. But it wasn't too much labour to get them to fit.
This evening I'll get the manifold back on and flash her up sometime tomorrow perhaps...
PostPosted: Sat Apr 16, 2011 7:14 pm
completed the dismantling of my gearbox.
Then put it back together with new layshaft and bearings,
New straight cut drop gears,
New 4 pin diff
new 3.2:1 crown wheel and pinion
Tommorrow I hope to fit back onto the engine.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Apr 16, 2011 8:04 pm
NAV-MAN
Today i did some more rust hunting. Fortunately only a small bit of surface rust. I also got around to cutting out and patching some of the worst stuff.
I might even be able to think of doing some panel work soon.
PostPosted: Sat Apr 16, 2011 8:40 pm
did a photo shoot for Unique Cars
with a mini 850,mini K/1275 ls.moke califonian and my 73 leyland van
will be in next months issue long day but good fun
just found out i am the 3rd ownerof the van and is still on original plates :D :D :D
PostPosted: Sat Apr 16, 2011 8:41 pm
Attached the Amp to the radio & speakers and now have the Sub connected. Just need to find some boxes for the speakers and ill be happy.
Wireing under the dash all tucked away now also :wink:
PostPosted: Sun Apr 17, 2011 5:30 pm
Over the past 3 days...
-Installed Headlining
-Installed windows
-Electrics
-Refitted door locks/door windows etc.
-etc etc etc
Sooo finally got it done enough to go for a drive. :D
Nearly done, just bages and flares to go.
Also did a compression test, is 150PSI to high for all
cylinders?
PostPosted: Sun Apr 17, 2011 6:21 pm
cylinders?
I'd say 150 psi is pretty good, nothing to worry about.
PostPosted: Sun Apr 17, 2011 8:12 pm
Finished refurbishing the trailing arms.
Reconnected all the rear brake lines.
Continued stripping the engine bay paint :evil:
Finished the rod change remote and reinstalled into the car.
Removed 34 years of grease and hardened road grime from the rear subframe.
Repainted the rear suspension trumpets.
To do tomorrow:
- do the caliper piston insertions with new seals
- MORE paint stripping
Soon I have to work out the spagetti that is the engine bay electrics...
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Apr 17, 2011 10:13 pm
drove it to hobart and back,through my favorite twisty road,love that mini.
First you get the money,then you get the power,then you get the Mini.
PostPosted: Mon Apr 18, 2011 2:19 am
Noticed a fuel leak coming from the mechanical fuel pump yesterday. Had a closer look today and closed the bonnet again... Might fix it next week. :)
PostPosted: Mon Apr 18, 2011 3:10 pm
Milatsmadmini
got a blue slip ;)
PostPosted: Mon Apr 18, 2011 3:17 pm
Got my wiring sorted in the engine bay, started attacking some rust, decided I should start a thread for my rebuild.
So... I'm Seifer
PostPosted: Mon Apr 18, 2011 5:09 pm
The usual.....nothing :cry:
Users browsing this forum: No registered users and 180 guests
