Twin SU`s of any kind (if set up well) will produce far better economy than a single, so lets not get into the "2 carbs chew more juice" argument, cause it`s simply not the case
Just because there`s 2 carbs doesn`t mean that it`s using twice the juice...---> each pistron is still sucking through one carb at a time (for want of a better description) the benefits from a twin carb set up are that there is a far more even distribytion of mixture across all 4 cyls & also there is way less restriction of airflow, so it`s simply a far more efficient design--> threfor more power is avaliable when you plant the foot,,, but also less fuel used when on light throttle.
also if you`re game (& if your engine isn`t too high in compression ratio) then you can crank up the ign advance a tad & add a vac advance unit (if you don`t allready have one) to save even more juice,,, but ontop of all that, if you drive with light throttle as much as posible then you will save heaps. Aprox 85-90kmph is the most effective/efficient/economical speed, & maybe stick to the back of a truck & let him suck you along
ok, dangerous, so dis-regard that last statement
& 5000 rpms is not really bad for any engine, even helps clean out the carbon deposits
just that if you look/read thru your owners manual, it will tell you that driving for prolonged periods of time at high revs will consume oil
believe it or not,,, funny hey?,,, the factory warn you that you mini will chew oil if you thrash it, i thought that was very conciderate of them to let you know that they can`t build a high reving engine without chewing oil
My 1510 donk sits happilly on 7500rpms all day,,, & it has done that many many times, including 2000kms of Targa Tasmania Rally, & that`s after nearly 7 years of thrashing around the roads as my daily driver & at race meets twice a month. Dam good thing that donk
& everyone can stick their tall 2.9---&---2.7 diff ratios up their low reving doey pig. no acceleration, can`t rev, under powered engined exhaust pipes
dam even a 3.4 is way to tall for the average mini... poor little things can`t get a good reving in top gear. you all should be ashamed of yourselves,,, well the ones with 2.9 & 2.7s anyways
ok,,, i`m finished now,,, scald me if you will,,, i`m ready,,, i can handle rejection, i can take a bashing, common, you know you want to
