Mike_Byron wrote:
I had a lot to do with one of the best HQ racers of a few years back (Peter Dane). I learnt a lot about race car setup from him.
He won just about every HQ championship at one stage or another and it is about chassis development and tyres. His car was very very stock but very well developed. It was also big budget compared to a lot of others. He practiced on one set of new tyres and raced on another. He never ever went out on the track without fresh brake fluid in the calipers and wheel cylinders. The shockies and springs were tested for sepcification and either reset or revalved if they varied, after each race.
It was more attention to detail than cheating but the detail cost money and showed results. The final outcome of this series will be the same but its a ball anyway. Regardless of all above a true genuine talent will shine once race craft is learnt.
And here is an example of where some drivers/teams tried to get unfair advantages.
One of the rules stated that the rear axle must be solid - no universal joints or IRS setups allowed. This was so that all cars would have a relalively neutral rear end geometry.
Some drivers found that they could run a fat seam weld along the top of the axle which would bend the wheel ends upwards when the weld cooled, resulting in a couple degrees of negative camber. The downside was that they had to replace rear wheel bearings after every meet. The upside was better lap times.
It was a simple case of reading between the lines and bending the rules a bit.... without breaking them.
If you ask me, THAT is cheating....... even if it isnt breaking the rules.
Mini Mad wrote:
Yea...could be a market for some cheap unregisterable rover shells
That is exactly how Steve sold a few shells just 12 months ago - for the S.A. series that never started. The shells went for about $1500 to $2000 without subframes, engines, interiors, etc etc, just a bare shell. All you do is buy a wrecked clubby or whatever and transfer everything across.
The Rover shells are supposed to be slightly lighter than 850 shells too.
