feralsprint wrote:
without knowing what the fuel/air mixture is it is a pretty useless bit of info,
Please re-read the first post, slowly.
feralsprint wrote:
as has been stated you also need to know the temps and the ignition
advance and the RPM,
Are we talking about ambient air temp or engine temp?
Ignition advance and timing would only have to be in the ball park to
get the engine running and fine tuned as it needed to be.
RPM.. I presumed that would be a given.
The whole point of this exercise is to devise a better method than squinting
through a windscreen looking at a stick bobbing about.
Oxy sensors have been about for years and are readily connected to laptops. Why not use a sensor to read piston height and connect that to your laptop.
And then have a little program that draws up a needle profile for the car.
Some people are just making it far too complicated.
Thankfully some people are on to it.
Far be it that myself or Matt or GR or Morris try and help you understand that there is more to tuning a SU than knowing where the damper is sitting, it won't hurt anyone but I just want people that this gizmo is only one part of a very complex answer and that the rest of the equipemnet to actually be able to make sense of tthe readings is both expensive and time consuming to fit
O2 sensors are quite comon but they are designed to be fitted to the exhaust manifold to work best, tail pipe readers are Ok but a bit slow and you need the exhaust to be perfect with no leaaks at all but you must know all this as you dismiss what has been said by myself and others in this thread, I have read the first post annd am simply trying to help you out but you don't need help so please disregard evrything that Myself and the others have tried to inpart to you, i hope you have great luck building your widget
