It is currently Thu Aug 07, 2025 12:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Apr 12, 2010 10:50 pm
I used to stick magnets on the bolt inside the old canister filter they used to pickup lots of metal
PostPosted: Mon Apr 12, 2010 10:57 pm
gafmo wrote:
anyone notice the pun
No, the pun went south and the net magnetic moment went north. Maybe you needed a Poll (sic)? :D
PostPosted: Tue Apr 13, 2010 6:20 am
Tombo wrote:
Allrighty then.
I have 4 magnets on my filter......... and cutting it open with an exhaust cutter (so no swarf) there was about 1/8 of metal silt there, more than the magnetic plug could hold.
Yes, of course the magnets will hold some of the crap. But if they weren't there, it would not be going through the engine in any event. It would have been caught by the filter.
Tombo wrote:
On the subject of particle proximity to the magnet, look at it this way, i had a 1500L fish pond, the filter was at a guess 1L volume, this does not mean the filter only saw 0.00066% of the water, the pump flowed 3000L per hour. So the whole pond went through the filter every half hour which means it will end up catching most of the stuff there.
100% of the flow through your fish tank pond filter goes through the filter. On that example you have given it would take a little over 1000 hours to pass nearly all the water through the filter.
This is not the case in any car engine and with the magnet / filter theory although there is a good deal of flow through the filter, all that does enter the engine components in fact, hardly any will 'see' the magnets as only a tiny fraction will pass anywhere near the infulence of the magnets. With the filter ALL the oil has to flow through it, where as with the magnets a very small amount pass near them. A portion of the oil could never see the filter as it may never be picked up by the oil pump and even if it were, it could go via the by-pass valve.
Further, as VulcanBB18 has pointed out, there is a lot of non-ferous material that the magnets would have no effect on what so ever.
I have never bothered with magnets as would around 99%+ Mini Owners. To do 1000 kM in a Mini, the crankshaft turns over about 1 500 000 (1.5 million) times. That's only to do 1000 kM. In that distance the oil in the sump turns over about 700 000 (seven hundred thousand) times. So all those particals that get past the filter see the internal engine components in excess of 500 000 (half a million) times in only 1000 kM.
I don't see too many engines that have been ground away because magnets were not fitted. In fact I've never seen any that have been ground away.
An engine that I rebuilt back in about 1989, fitted to a customers Moke has never had magnets fitted. That engine (when I caught up with the owner at Wagga at Easter last year) had done over 300 000kM, with only routine maitenance done to it since it was fitted some 20+ years ago. Not a bad innings for an A Series Engine. As it still goes well, does burn some oil, but not yet needing topping up between changes. But it still has very good oil pressure and no noise from the bearings.
No magnets here.
Do the maths. How many times has that crank etc seen particals that have gotten past the filter?
As I have said above, if it makes your wife love you even more, then go for it :wink:
<EDIT> Yes Gaf, I saw your pun - that's pun, not bum!
PostPosted: Tue Apr 13, 2010 6:04 pm
bearing in mind that I am not a mechanic, and those that know me well enough really know that I'm not! :lol:
With that in mind, how small would a particle be to pass through the filter?
Are we talking microns? Would it be big enough to pose a problem to your engine? Even if there were "heaps" of these microns?
Just my "non mechanics" way of thinking, that with regular oil changes, and you have enough particles to pose a problem, wouldn't the issue be "whats wrong with my engine", not "how many magnets should I run"?
As I said, these are questions from a lamons point of view.
mooo, I'm a pig!
PostPosted: Tue Apr 13, 2010 6:44 pm
If the filter picked up all the crap then the oil would not go black
PostPosted: Tue Apr 13, 2010 6:58 pm
I wish I was allowed to say what I think. :mrgreen:
But I made a promise.
PostPosted: Tue Apr 13, 2010 8:00 pm
Chicken! :lol:
PostPosted: Tue Apr 13, 2010 8:08 pm
The Forkmeister
Chicken! :lol:
Stop it Scott :P
May the fork be with you.
PostPosted: Tue Apr 13, 2010 8:40 pm
Chicken! :lol:
Stop it Scott :P
PostPosted: Tue Apr 13, 2010 9:14 pm
Could one argue that magnets extend the life of a filter? If there's less metal in the filter then it has more surface area available to do its job better, longer.
PostPosted: Tue Apr 13, 2010 9:23 pm
OKay getting Silly now :roll:
I will lock it :idea:
Yep. That is one of the advantages that I see.
PostPosted: Tue Apr 13, 2010 9:41 pm
Tomboss Breweros
So it works like the cyclonic air intake on a 4x4, stops some of the crap getting to the filter, makes it flow better.
And yeah, it makes me hard, gets my wife wet, makes 25 hours in a day and it looks better, so i like it :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Apr 13, 2010 9:55 pm
Ive got 20 magnets........On me fridge, they work well, hold things up n stuff :lol: :lol: :lol: :lol:
