It is currently Sat Jul 19, 2025 7:38 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Dec 03, 2011 5:41 pm
74snail wrote:
Righty-oh , found the bloody recharger for the camera , little bugger made itself hard to find , so my 1275 auto is factory sprayed 222 Light Bronze Green , there are several small patches of overspray but its very,very obvious there is no Gold paint anywhere
the paint on the gearbox has faded to a pale green silver , on the head a slightly darker pale green silver , there is no paint under the 222 Light Bronze Green
It is not out of a Matic or and 1100 it is?
What is the engine prefix? (does it have cut off rivets in the holes next to the engine number?) I have a theory! :D
PostPosted: Sat Dec 03, 2011 6:01 pm
Back in a sec !!!
PostPosted: Sat Dec 03, 2011 6:09 pm
Morris Nomad
12 70 YG5S1 1136
12 YEA H 3727
Does that fit your theory ?
PostPosted: Sat Dec 03, 2011 6:17 pm
74snail wrote:
Morris Nomad
12 70 YG5S1 1136
12 YEA H 3727
Does it have the cut off rivets or empty holes next to the engine number?
PostPosted: Sat Dec 03, 2011 6:22 pm
Back again , empty holes and also a back to front E stamped under the temperature sender
PostPosted: Sat Dec 03, 2011 7:11 pm
Empty holes and the "Y" in the engine number point to it being an Australian produced motor.
It was not fully imported from England or it would have cut off rivets in the holes.
The engine colour was changed for the new model.
It will only have one colour because it was not resprayed like the Matic and Morris 1100 motors.
PostPosted: Sat Dec 03, 2011 7:22 pm
So I have to assume the E punched under the temperature sender stands for , not sure ?
Well , thats new to me , as far as I knew all the automatics were brought out from England , now to the next point , just when did they stop using BMC paint codes and switch to Leyland Australia paint codes , it must have been at the end of 73 ( engine paint that is )
PostPosted: Sat Dec 03, 2011 7:34 pm
What do you mean BMC and Leyland Australia paint codes? :?
The codes were Berger and Dulux depending on who made the paint. BMC's own number was the Berger code with their own prefix code in front of it.
PostPosted: Sat Dec 03, 2011 7:46 pm
Sorry, I should have said , engine paint codes used by BMC / BLMC and then Leyland Australia
PostPosted: Sat Dec 03, 2011 7:50 pm
Do you mean the BSC colours like the chart that you posted on the first page?
PostPosted: Sat Dec 03, 2011 8:06 pm
Yes , that,s the chart I came across in a thread on MK1 Peformance on " Engine paint - codes , colors etc " ( if I remember rightly ) , the part of the thread that interested me was the brief three or four post discussion on automatics and it was mentioned about the 222, 223 and 224 codes and one gentleman posted the BMC British Standard Color Chart , I don,t exactly remember the rest of the thread but it was mentioned about engine exports and CKD cars , after that I did my own searching and it pretty much confirmed it , I,m happy to admit there are holes in my exact knowledge as in what we have discussed re my engine number
PostPosted: Sat Dec 03, 2011 8:13 pm
It is not a BMC colour chart. It is a BSC colour chart. It is the British Standard Colours.
It has nothing to do with BMC even if they did use some of the colours. Ford would have used them too.
PostPosted: Sat Dec 03, 2011 8:27 pm
See , another hole in my knowledge , I was going on what was posted on Mk1 Performance and what I researched seemed to back that up , but if what I posted re the chart is wrong, then its wrong
PostPosted: Sat Dec 03, 2011 11:13 pm
When looking at the Mini Experience Issue 2 has an article on the DeLuxe. It has a photo of what I expect would be a deluxe engine.... which is light green metallic.
http://miniexperience.com.au/issue-2/mini-deluxe.html
If anyone has issue 2 they might want to check the article out. I don't have issue 2.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Thu Sep 24, 2015 4:34 pm
Original UK engine out of my 68 Matic .
Light green metallic under
Non metallic dark green painted over top
Simonw
Brisbane QLD
- 1969 Mini K
