It is currently Fri Aug 22, 2025 10:38 am
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu May 22, 2014 8:20 pm
For a cost of under $50 I would bin all the guides with no 2nd thought.
Also I'd measure the valve stems, if they are worn more than .001" smaller then the top part near the collets, I'd replace them all too.
Mini parts are CHEAP compared to modern cars.
PostPosted: Fri May 23, 2014 2:59 pm
so just replace the lot then? guides and Valves
PostPosted: Fri May 23, 2014 4:18 pm
on another note! I have roughly measured the bore (with a ruler I do not have a vernier caliper yet) at approx 72mm how big does this make my engine
Thanks Andy
PostPosted: Fri May 23, 2014 5:31 pm
Give Ash some flowers Nick .
well measuring with a ruler is very hit and miss as there is only 0.5mm difference between a 0.040" and a 0.060" overbore. Assuming its 0.060" over (1275 + 0.060 = 1328....) it is a 1330cc.
PostPosted: Fri May 23, 2014 6:10 pm
thank you. I'm aware that it was a bit vague but at least i have an idea for now. cheers
Users browsing this forum: No registered users and 289 guests
