david rosenthal wrote:
I did end up with a 289 ford V8 in one[ the pic on tthe left] Ran in sports closed late 60's, but there was "some bloke" in a blue Austin A 30 who would drive around you!!!!!
I'm sure the bloke was a hack, and never amounted to anything.
There's still a Minor with a 289 and two speed auto getting around Sydney... There are heaps with Datto A series motors, Toyota 3K/4K/5K/7K motors (one's even supercharged
), people are starting to do Toyota 4A-GE, there's at least one with a Commo V6, Subaru EA81/82... Fiat twin cam's been done a fair bit, too. And, of course, overseas, where it's legal, people put in Rover V8's.
Or, in the US, Chev and Ford V8's...
Steering rack location's a common problem, mainly because the engine bay's so short! It's only about 500mm long if you use a radiator at the front. So modern 2L engines generally don't fit. Unless you cut the firewall... And then you've got to contend with the rack. Many people use Major steering arms and move the rack inside the car... People using Dattos usually notch the gearbox/bell housing.
But forward mounting the rack - whilst a not inconsiderable amount of work - is an interesting idea... Especially given that most new RWD cars are done that way - even Commodore's gone that way now...
I'm guessing that the 289 probably sat a fair way forward... And there may not have been many thicker torsion bars available back then (just as there aren't many now)... So I'm guessing it handled like it had a boat anchor out in front..?
