when I use the bike tune-up programme set-up with the honda CV carbys I found that there are a few interesting things that occur.
the honda carbys work basically the same as a SU, and the air flow measurement is important. the computer will give a readout at the same engine rpm either under accel.or steady rpm. this will them tell you how much air is getting into the engine and a air/fuel ratio and the position of the needle. the ideal gas law- Pressure,volume,temp
I found that under certain conditions the mixture leaned off and this increased the cylinder temp.
the piston is lifting due to differential air pressure and you can have same diff in pressure ,but a big difference in volume of air into the engine.IE piston height and butterfly position. One of the tricks that steve showed me was how to modify the piston to get better lift as the air flow increased when the butterfly was fully open.
With this mod the engine can be accel from any steady rpm and it will go to excess fuel[piston lifts to max] then as air flow increases settle back to required position. every time the throttle is snapped open the engine has a puff of black smoke then settles down.
With exhaust temp this is critical as a variation in air/fuel may be slight but due to load the temp will increase rapidly. the alumin pistons do not have a big lee way before they reach deformation temp.
I found that with inlet v/v timing was critical as the extra air flow helped to drop cylinder temp and cool the pistons.
One of my early test engines had the extractors glowing red hot under full load and the piston crowns were badly deformed after I stripped it down. I know that the exhaust temps were around 575-600 deg C at head out-let but increased to over 700 into the extractors. By adjusting the inlet cam timing the cylinder temp dropped and the extra air dropped the extractor temp considerably.
this set-up has a ring with a internal groove and a outlet fitting to a pressure guage that fits under the spark plug . so as the engine is running the cylinder pressure can be measured[effective mean pressure] and this is what HP calcs are worked out from.with 4 seperate carbys/cylinders/exhaust this is easy.
What you are doing with this programme is good to see what is happening with the carby,but more info is a helpful thing to see exactly what is happening to the whole engine package. I am lucky I just borrow steve's expensive toy
www.minisprintgt.com
