It is currently Mon Jul 21, 2025 4:08 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 43, 44, 45, 46, 47, 48, 49 ... 568  Next
PostPosted: Mon Jun 15, 2009 10:27 am
NAV-MAN
I pulled the engine apart to discover the front main bearing looks good with no scoring etc but my centre main and rear main bearings are flogged and are thru the bearing material in places and te rear has a big score all the way around both halves of the bearing.
All the bearings on the conrods are looking ok.
Should I have the crank checked as all the journals are already -0.040" undersize. If ok linished and polished witn new bearings to suit or is it better to go get another crank?
PostPosted: Mon Jun 15, 2009 10:31 am
forgot to the put the grill back on after working on it on the weekend...it looks odd atm..kinda toothless...goes straight back on when I get home :)
PostPosted: Mon Jun 15, 2009 10:40 am
ginger ninja
ginger ninja
Yesterday Mini_special changed her brake light switch, changed dissy cap/leads/coil/rotor button etc and flushed the brakes. I was given the task of sitting and watching :) She's much happier now :)
sports850 wrote:
PostPosted: Mon Jun 15, 2009 7:53 pm
Measure all the crank journals with a micrometer.
If worn more than .001" oval, or scored, I'd find another.
Beyond -0.040", sorry but that crank has had its day.
If worn, linishing won't save it.
PostPosted: Tue Jun 16, 2009 9:10 am
NAV-MAN
Figures, such is my luck lately. at least 998 cranks are cheap. or that 1098 I have in the corner of the garage is starting to look good to build that.
I also forgot to mention that when spinning the crank by hand it comes to a spot where it is difficult to turn, same spot every time. Is that a sign of a bent crank?
PostPosted: Tue Jun 16, 2009 2:50 pm
I investigated the source of water ingress to the rear compartment of the clubman estate. The rear sliding window channels (similar to Mk I & II front windows) are a consumable item - they grow moss and need to be replaced every 40 years it would seem. Built-in obsolescence!
Luckily BasisNZ is a great stockist of such parts so I should be able to source new runners fairly easily. If you need any trim, check them out.
I also cleaned all the muck from around the spare wheel compartment (under the rear floor) and treated the rust. The water ingress may not be due to the window rubbers, but they need sorting. I will investigate further with a garden hose in the weekend.
And I looked longingly but dispiritedly at the shell of my Mk II which is awaiting attention and has been for six months. Ho hum.
PostPosted: Tue Jun 16, 2009 7:29 pm
Finished the rebuild and painted an 1100 motor for a friend. Tomorrow the 850 comes out to reclaim the box before dropping the new motor on it.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Tue Jun 16, 2009 10:38 pm
cut a nasty bit of rust out of that triangler brace that the wiring loom runs through just in front of were the subframe bolts to on the drivers side .now all i need is a decent mig, ... :)
PostPosted: Wed Jun 17, 2009 4:02 pm
Today I went to the post office and picked up the BMW mini supercharger, Austin cooper s boot script, reconditioned late model MGB tacho (can cope with performance electronic ignitions), and the 60s motolita steering wheel I brought for the project. Less than a month and I'm university free and able to actually work on the project car not just spend money buying bits for it. I can't wait.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Wed Jun 17, 2009 5:31 pm
I wish my post office had so much good stuff.
Got my mg metro rocker cover from team fancy pants. Thankyou sir!
PostPosted: Wed Jun 17, 2009 8:35 pm
Tomboss Breweros
Borrow mine, it will weld the thin metal better :wink:
I got my minis into the new carport. Still not much room but at least they are out of the weather and behind a gate.
Layla is still covered in Hay mud and still has a scuff on the paint where i hit a marker :oops:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Jun 17, 2009 9:19 pm
Took the 850 motor out today and separated the block from the gearbox, took the radiator to the radiator specialists to get cleaned and pressure tested and get it back tomorrow. Big cleanup of gearbox and engine bay (lots of oil leaking everywhere) before reassembly with the nice clean and freshly painted 1100 block.
PostPosted: Wed Jun 17, 2009 9:36 pm
Fitted a CD player to the Moke, with output jack for headphones so the missus can listen to The Carpenters on our next trip, and I DON"T have to listen the The Carpenters on our next trip.
PostPosted: Thu Jun 18, 2009 4:59 pm
Getting a 45 weber fitted this week, cant wait it get it back! :D
PostPosted: Thu Jun 18, 2009 5:20 pm
Replaced both side back window seals,now the windows lock,Thanks Doc
Replaced the drivers door lock stop and adjusted the door lock.
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
