It is currently Sun Aug 03, 2025 6:49 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Thu Jul 16, 2009 8:21 am
Our new flywheel & clutch package--->
We have machined all the surfaces nice & flat, set up the 3x pillars to suit out new machined & press fit clutch pivot ring,,,it shifts the diaphrams pivot point, effectively changing the clamping force on the clutch plate
we have done this mod quite a few times in years gone by, but both Stews Race mini & our turbo twin cam moke need plenty of clutch grab, so we`ve done it again.
"Normally" std-ish blue diaphs will give about 6-700lbs,,, orange will give about 8-900,,,greys will give about 11-1200,,,depending on how they`re set up
we have created this set up , with a Blue one which gives 1500lbs,,, our grey made over 2000lbs of clamping force with this same mod :-)
hope we don`t have any more clutch slip for a while
Oh!!! & the new clutch plate friction discs are not cooper, they`re called "Carborundum" (spelling?) apparently they allow a bit of extra drivability (less of an on-off switch) ,,,a little easier to drive & don`t collect as much heat as copper.
PostPosted: Thu Jul 16, 2009 8:24 am
I am very impressed by your package - your clutch package that is
PostPosted: Thu Jul 16, 2009 8:26 am
yeah i know,,, all the girls say that :-)
PostPosted: Thu Jul 16, 2009 1:24 pm
My clutch has the same stuff (Carbon Ceramic) as friction material.
I'm running 800kg clamping force, ~1750lbs and it's awesome but a mean bastard at the same time. Mine is an on/off switch.
Will be interesting to see how yours goes 8)
PostPosted: Thu Jul 16, 2009 5:57 pm
wouldnt the plastic bag clog things up :P
PostPosted: Thu Jul 16, 2009 6:34 pm
My Kombi clutch is 2600lbs , i have to replace the cable about every 6 mnths tho :-(
I might have been ripped off tho,,, mine didn`t come with the plastic bag :-)
PostPosted: Fri Jul 17, 2009 9:11 am
ausmini mod
ausmini mod
No no - it works fine but keeps dust off it at the same time... very good idea. Like a vacuum, when you change the clutch you just throw the dust in the bin and its all spotless.
Ceramic buttons (even with cushion) are still a mean bastard... if its a daily driver and you have traffic (do you have many cars up there Matt - mainly horse and cart and tractors right? j/k ) its a pain... effective though, but a pain
Pete
PostPosted: Fri Jul 17, 2009 9:53 am
Horse & cart??? we`re not "That" wealthy up here... crickey i`m saving up for a pair of shoes at the moment, one day i`ll be able to afford the laces to do them up :-)
The Carborundum plate is for Stew`s sports sedan, the Moke has the comp AP plate
& yeah i`ve driven many many years with puck plates Pete,,,
hee hee ---> Puck Plates Pete...
Peter Piper picked a peck of Petes puck plates :-) Plenty people pike on puck plates but perfectly pertaining to performance properties are the puck plates pete :-)
PostPosted: Fri Jul 17, 2009 10:27 am
:D :D :D :D :D :D
that got a good giggle
PostPosted: Fri Jul 17, 2009 12:39 pm
If someone with one of those clutches is going to kick you in the ar*e make sure they use their right leg :shock:
Good for muscle development
www.minisprintgt.com
