It is currently Fri Aug 22, 2025 2:56 am
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 15  Next
PostPosted: Fri Jan 28, 2011 8:00 pm
Oh dear, worry, worry...
Hi Chris
I said i don't know i'm trying to get the original blue prints from Paul Ivy
Graham
PostPosted: Fri Jan 28, 2011 8:21 pm
Mini_Maxx wrote:
WOW :shock: This is epic
I don't know about epic but this has turned into a pissing competition. Half of these posts should be PM's :? It really looks poor that some very very knowledgeable people on here start to carry on like children. This thread should have been left locked.
PostPosted: Fri Jan 28, 2011 8:28 pm
I think it should run.
Let the people that know this stuff work it out.
Others with less knowledge should not interrupt unless they have question
or a bit of humour or something.
PostPosted: Fri Jan 28, 2011 8:40 pm
Hey scotta_74, fine. If you don't like it, don't read it.
PostPosted: Fri Jan 28, 2011 8:53 pm
This space for rent
Mick wrote:
sgc wrote:
Guys, please. Let's keep it civil?
Keep it civil.
Pretty please, with a cherry on top. Keep it effing civil?
I'm sure plenty like me are enjoying the discussion and learning heaps, but the pissing contest makes everyone involved look like school kids...
PostPosted: Fri Jan 28, 2011 10:22 pm
Maybe someone should make a crank out of Nylon or Ebonite, that might work.
Have a Nice Day.
PostPosted: Fri Jan 28, 2011 11:58 pm
it`s cool,,, these guys will sort it out,,,,, won`t you???
it`s healthy discussion, right boys???
& Besides,,, we`re all little kids, no matter who we are,,, & if you diss-agree then you`re lying
so,,, GR , send the sample
GT, test the sample
i`m almost more than half agreeing with GR, but i don`t have enough knowledge about metallurgy to input much
& i`m almost half agreeing with GT too because i,,, after many years of "Feeling" this crap with big donks & big revs, & then seeing results of others doing things differently to Dad,,, well,,, i`m keen to see the facts of at least one particular crank,,, that`d be pretty damn cool
if you`re not keen to see the results,,, or if you want to just see the p!$$ fight through... then cool,,,, lets see this one through & then walk/run/sprint through the valve spring debate immediately after, while we`re on a roll
i love facts,,, they beat all pub talk,,, feeling it & seeing it & then "Knowing" it is better than just imagining it
GR,,, send the crank
GT,,, test the crank
OK???
then lets get on with the valve spring thing
in the mean-time,,, i`ll talk with my Guy in China & we`ll see what their best material that China is using for cranks these days & compare
yeah???
this is a damn good thread,,, Please do not stop this thread,,, it is one of the very most important pieces of the puzzle that this forum has endured so far & needs to be seen through
BUT!!!!!!!!!!!!! Gentlemen,,,, lets stay classy gentlemen,,, no pulling hair or scratching eyeballs ok???
Let the games begin, But be nice & we can all learn from this
PostPosted: Sat Jan 29, 2011 1:31 am
GR wrote:
now here's a little some thing ENGLAND is the only country in the world to make EN40b, but wait theres more the yanks make 99%of there cranks out of 4340 or 4140 but wait there's more they now make 4140 with 1% aluminium so they can nitride it but wait there's even more 4140 does not have any nickel in it but 4340 does.
GRaham Russell
Not quite correct about england being the only country to make EN40b.
Now the EN part was a standard code[EN=EN-glish] and the 40 code is a carbon content base, and the b is a code for the other metal elements.
The EN system standardized in UK in 1959 and continued until 1990 when just about all countries standardized on their own internal codes, but also complied to world wide codes, IE AISI american iron and steel insitute, SAE for automotive production and Werstoff number which is the european DIN then there is japan, china etc,etc.
So if you asked for a lump of EN40b then here in Aust. the code number is BS.970.722M4 [Aust works under the british standard for steel] but has a Aust standard for construction compliance.
Now B.S. 970. 722. M. 4.
BS970 is british standard for the base grade of the metal
722 code for a alloy steel. you then look at the code No. in the british std. and it will give you the composition.
M supplied to a particular mechanical property. IE machineability
4 the mean carbon content x 100.
So this particular grade of steel has equivalent composition listed in all other countries standards.
4140 and 4340 are AISI standards and if you look up the composition for them and cross reference them to a BS number guess what the numbers come up and then cross reference back to the old EN No's and the chemical composition is the same as en40b and en41b.
If a particular composition is not manufactured then there is a cross reference with all world wide steel producers to a steel that is very close.
all this was done because if a ship was built in say europe and you were broken down in singapore and under your class certificate the componet was made from say en40b then you can source a equivalent in asia. World wide standardization.
http://www.mencinger.biz/SteelData/Equi ... 0Steel.htm
The poms still use the EN system for their domestic supply thats why if you look for en40b england is the only country to list it as en40b
Like this stupid metric system we have here. It was supposed to make things simpler but, the imperial system for ever
www.minisprintgt.com
Last edited by david rosenthal on Sat Jan 29, 2011 1:36 am, edited 1 time in total.
PostPosted: Sat Jan 29, 2011 1:35 am
GR wrote:
You went on about not being able to nitride steel with out chromium in it but you forgot about the most IMPORTANT PART for NITRIDEING that is ALUMINIUM for this is what the nitriding follows in to get the depth with out it it will just sit on the top of the steel also if you have any NICKEL in the steel it will reject the nitriding.
I didn't go into that, because it was not relevant to Matts point. His point was corrosion resistance I just mentioned in passing that in ferrous steels, Cr needs to be present in some quanity along with other alloying elements.
GR wrote:
En40/b is the only steel for proper nitriding,
Incorrect
... they now make 4140 with 1% aluminium so they can nitride it but wait there's even more 4140 does not have any nickel in it but 4340 does.
When did the start making 4140 with Al in it. And what is its correct designation. It wouldn't be SAE 4140 anymore if it had Al in it.
Now heres one for you a new steel that the drag boys are now using is H13 which is a TOOL steel :lol: but you could never make a crank out of tool steel could we. Sure you could, if you had $5k for the billet, then machining and design on top to do a V8 crank.
GRaham Russell
Please read
Phat Kat wrote:
david rosenthal wrote:
GT mowog wrote:
TheMiniMan wrote:
the cranks we had tested for hardening depth years ago (my dad did this when i was a kid) & worked with "Heat-treatment" up here in Brisbane --> the hardening would go about 15-18thou deep, & also found it to be very uneven through the crank,,, but if we left the crank in the center of the tank, for the whole weekend, the depth increased to 25-30thou & was more even thickness right through the crank
Matt, a couple of quick (if there is such a thing) questions;-
What type of 'hardening' did these cranks have?
What type of 'hardening' did you dad do (or did he have it done)?
when I was working at rev-master we used a combination of sodium cyinide and potassium nitrate for the case hardening and sodium chloride for the tempering .
When we made the billet cranks the base metal was either Q10 or L7 ,[a spring steel compound] these metals had a high resistance to twisting, but if they were hardened over the complete surface then they would become brittle and suffered from surface cracking.
The wearing surfaces were only hardened. The cranks were coated with a asbestos refractory compound with the wear surfaces exposed then immersed in the salt bath.
Very hard overall is not good ,imagine a crank made of tool steel
Awww, here I was thinking that a nice big ol' lump of Stavex would make a great material for machining a crank out of :D
Not to be a twat at you David :) buuuuuuuuuuuuuuut you know that Technically L7 is a tool steel (or at least its listed in the tool steel charts) :mrgreen: But what you have said is correct, high resistance to wearing and twisting. ER collets are made out of it.
I wasn't denying that you could use tool steels for making crankshafts.
GT mowog wrote:
GR wrote:
with the EN40b steel with .060 of nitriding for strenth and stiffnes
So if it's 0.060" in depth (which is not possible BTW), why then do BMC themselves recomend re-nitride treatment at 0.020" re-grind intervals? and re-nitriding to a depth of 0.012 to 0.015"?
Remember, keep it civil.
GT mowog, please keep this in mind...
Phat Kat wrote:
GT mowog wrote:
FYI, nitriding to 0.060" depth is impossible
Hold that thought....
This nitriding depth on S cranks has been debated for years, rumour has it that Rolls Royce did the heat treatment.
I have an EN40B S crank that went into my 1360 after regrinding to -.020"/-.020".
After a few laps of Wakefield Pk (motor had 1000 miles up) with the factory recommended .003" crank end float, it trashed the thrust washers, and the centre main bearing almost spun in the housing.
I took the crank back to Spiro at St George Cranks. He reground the mains to -.030" size. He commented that it was still nitrided, and still as hard as hell. So there ya go- my 2c worth.:wink:
Good to know Doc.
Now, I didn't say its impossible, i said getting 0.020" was an effort and expensive.
For most places to reach 0.020" they need to do it in a few hits. And its dear....
IF you can get it to 0.060", I don't think it would be commercially viable on a mass production item considering that the car was worth under $5000 brand new.
PostPosted: Sat Jan 29, 2011 1:55 am
I was refering to" tool steel" as high speed steel . H13 is classified as a steel for tool making ie dies, punches and injection moulding etc, it is NOT a tool steel like HSS
If is was a compund like HSS then you would have to anneal it to machine it and any slight heat what so ever would re-harden it. If you ever got a crank made out of it it would shatter like glass but never wear out.
Injector pump plungers in big diesels are made from H13[and similar compounds] and then hardened and ground to survive the gritty crap HFO going thru them.
with H13 any surface hardening must be localised IE a punch end and the hardening is only a few thou deep and maintain a non hardened core or it will impact and stress crack. In its unhardened state it is very tough and will withstand a relatively high impact, but it's down side is that it will work harden and become brittle. Might be OK for a drag car when the crank only does a couple of runs.
PostPosted: Sat Jan 29, 2011 6:33 am
GR wrote:
we just to make the crank as stiff as possible which BMC did by getting the nitrideing in as deep as they did .060 to stiffen the crank, try telling these heat treatment people today how deep it is and listen to there answer they just tell you your all BS.
Just to be clear on this, are you saying that you like to make your cranks 'stiff' so they rigid and resist 'flex' etc?
PostPosted: Sat Jan 29, 2011 7:39 am
En40/b is the only steel for proper nitriding, now we have a lot of cranks made by Arrows of formula one fame and Cosworth for our historic motors and guess what they will only make them out of EN40 B and nitride them, now 50 years ago a little firm [BMC] wanted to build the best crankshafts for their little competion motors after many millions of dolllars they came up with the EN40b steel with .060 of nitriding for strenth and stiffnes but this was before the net came along may be these three companies should have waited and learnt how to make crankshafts now here's a little some thing ENGLAND is the only country in the world to make EN40b, but wait theres more the yanks make 99%of there cranks out of 4340 or 4140 but wait there's more they now make 4140 with 1% aluminium so they can nitride it but wait there's even more 4140 does not have any nickel in it but 4340 does.
GRaham Russell
Great stuff GR...can't help thinking though that if BMC had spent just a few more dollars on crank design and mounting to get rid of whip then the nitriding would have been the icing on the cake :!: :D
PostPosted: Sat Jan 29, 2011 9:51 am
it`s funny tho (i reckon) because there seems to be a need for "Some" compromise,,, now i actually hate that word "Compromise" , i don`t like having to compromise,,, i`d much rather have the best in everything,,, but with regards to cranks & from what i`ve learnt over the years, there is a need to have a stiff crank that resists twisting/flexing, but must also be hard enough to resist wear as well,,, that (to me) Must be a compromise in materials & treatments,,, it`s therfore the balancing of the composition & the processes placed upon the item to allow the best "compromise" for it`s intended purpose
The info in this thread is awsome & i think it`s well overdue
Now, getting onto what Mick just said,,, i reckon BMC did a pretty damn good job at Compromising,,, here we have an ancient design, adapted for the mini purpose from an even more ancient design,,, yet the bottom ends hold up relatively well with 200hp,,, when the original ancient design was barely able to hold 25hp without dramas,,, so the cranks actually do a damn good job & the 3 mains allow less frictional losses (when built well) less than the friction that a 5-main crank endures
but then the stiffness of the 5 main would surely allow even more power with less fatigue yeah?
so it`s all been a compromise process the whole way along the evolution of the mini engines components
later materials & chemical properties & metallurgy & machining processes have seen some awsome strong products being produced,,, but we still have an ancient designed 3 main engine still producing more & more Horse-power & able to cope very well indeed even with age old materials... IE: there are still some original "S" cranks buzzing around copping well over 150hp,,, how good was the original design/materials that we can have this ???
i`m loving this topic
Edit--> great info on the materials etc David,,, clears up lots of stuff for me & very calmly & sensibly put... well done
PostPosted: Sat Jan 29, 2011 10:05 am
I think that if an extra main bearing is needed it probably should be behind the flywheel.
(just one crank after another)
PostPosted: Sat Jan 29, 2011 11:48 am
OK???
Matt,
Thanks for your further input on what your dad did all them years ago. Just a little more info, Nitro-carburising is a general Treatment Term and Nitriding, Tufftriding etc are specific types of Nitro-carburising.
If GR sends it, GT will have it tested - independantly and post the test certificate. Mark my words.
GR, why not post the results from the testing you have had done?
Users browsing this forum: No registered users and 213 guests
