Mini k outer door sills
https://www.ausmini.com/forums/viewtopic.php?f=2&t=100259
Author:  Cornholio351239 [ Wed Aug 05, 2020 10:49 am ]
Post subject:  Mini k outer door sills
Hi all,
I've just purchased a mini k rolling shell which needs a bit of work on the shell. The drivers sill is rusted and has an outer sill welded over the top. I am planning on replacing both sills but not sure what the original sill looked like. Just confirming it is the same as the Mk1 with the 4 indents. I saw on the youtube video below a 1969 mini k which has 6 raised sections on the sill (about 29-30 seconds into clip) but is this original?:
https://youtu.be/6LA6sZOwSdA
Author:  Goldbrocade_62 [ Wed Aug 05, 2020 12:04 pm ]
Post subject:  Re: Mini k outer door sills
Australian cars had 1 vent at the rear
Author:  Cornholio351239 [ Wed Aug 05, 2020 12:16 pm ]
These are the ones available on minibits.com.au
Author:  Scoop [ Thu Aug 06, 2020 7:42 pm ]
I would use the 4 vent mk1 panel, you will get a better finish as the curve is shaped in to it.
Author:  Goldbrocade_62 [ Fri Aug 07, 2020 5:10 am ]
I personally wouldn't use any of the pictured the top 2 are horrible cover sills and the bottom one needs a curve in it
Author:  Cornholio351239 [ Sat Aug 08, 2020 6:37 pm ]
Which non-cover sill would you recommend? Could you send a link. I was thinking of this as an option:
https://oz.minisport.com/mcr11-33-01-28 ... mk1-3.html
Author:  Goldbrocade_62 [ Sat Aug 08, 2020 8:09 pm ]
Are you restoring for originality?
Author:  Cornholio351239 [ Mon Aug 10, 2020 6:43 pm ]
Yeah, it's stripped down completely for a rebuild so may as well get it looking as original as possible. There is an over-sill on the drivers side at the moment which I'll remove. The drivers footwell is ok but has been patch in a couple of places and there is hole towards the back. The mk1 complete sill to 1st groove should sort out all the rough parts.
