It is currently Fri Jul 04, 2025 2:40 am
PostPosted: Sun Aug 09, 2020 9:47 am
Hi all
Can you use an electronic distributor (pointsless, Hall effect I think) with a positive earth car.
I’m building an engine for my daughter and want to minimise maintenance and improve reliability for her.
Phil
PostPosted: Sun Aug 09, 2020 9:59 am
You just need to buy the right one
http://www.accuspark.co.uk/kit_search.html
PostPosted: Sun Aug 09, 2020 10:37 am
Thanks Tim
I couldn’t find a positive earth kit for a 45D.
As it is a simple two wire system, I’d have thought you could just reverse the connections to the coil and earth.
However, perhaps the polarity of the magnets has an effect on the direction of the current.
All a bit above my pay grade unfortunately.
Phil
PostPosted: Sun Aug 09, 2020 11:35 am
You can definitely not swap the wire's around, the module will be cactus. Just get a complete positive earth electronic dizzy, more often than not an original one is slogged out in the bushes and not worth putting a module in it.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Aug 09, 2020 11:47 am
Just swap the car around to negative earth Phil - unless you need to keep it bog-stock original of course.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Sun Aug 09, 2020 4:35 pm
Did they make any factory cars with positive earth and a 45D? Might be hard to find...
PostPosted: Sun Aug 09, 2020 6:36 pm
Timmy
The 45D is for the 1275 we’re building for my daughters 850 which is still positive earth.
Yes we could change it (if we knew how) but it just adds to the list of jobs.
PostPosted: Sun Aug 09, 2020 7:37 pm
Here are a couple of guides
http://blog.simonbbc.com/classic-car-pr ... -ignition/
https://www.minimania.com/Electrical_polarity
PostPosted: Sun Aug 09, 2020 8:44 pm
Thanks Timmy
That’s pretty simple (even for me).
Phil
