Primary Gear Spacer
https://www.ausmini.com/forums/viewtopic.php?f=2&t=100334
Author:  cooperess [ Thu Aug 27, 2020 9:21 am ]
Post subject:  Primary Gear Spacer
Where can I gear a good replacement for this part.
Author:  Morbo28 [ Thu Aug 27, 2020 11:02 am ]
Post subject:  Re: Primary Gear Spacer
I bought mine from here
https://classicmotoring.net.au/search.p ... +gear+shim
Obviously you need to measure clearances to figure out which one you need.
Author:  cooperess [ Thu Aug 27, 2020 11:11 am ]
'Morbo28" Not that shim. It goes on where the oil holes are, where the oil seal runs.
Author:  Morbo28 [ Thu Aug 27, 2020 11:13 am ]
Ah!
Author:  drmini in aust [ Thu Aug 27, 2020 11:17 am ]
More than half the primary gears I've seen out there are missing that oil slinger. These days with decent seals they work fine without it.
Edit
The black Rover MPI seal allegedly seals better according to one Mini repairer (not GR) I know.
I've not had one leak either.
