It is currently Sat Jul 26, 2025 11:33 pm
PostPosted: Fri Aug 28, 2020 10:07 pm
Purchased new wiring loom for Mini K / Mk 2 Copper S. Didn't state that it was for a Dynamo. Expected one for an alternator. What's involved to make it compatible ?
Sent from my SM-G975F using Tapatalk
PostPosted: Fri Aug 28, 2020 10:22 pm
In case you are thinking of returning it the Mini K and MK II S both had an alternator from first production, never a generator. If that's what the supplier was meant to supply and what it says on the package then they got it wrong. Can they fix it for you?
PostPosted: Fri Aug 28, 2020 11:03 pm
I bought this loom from England, so returning it could be difficult under this current climate. Ill email them and see where I stand, and why the description wasn't clearer.
PostPosted: Sat Aug 29, 2020 5:36 am
Ah well the UK MK2 still had a generator so that checks out.
Are you using an original alternator with an external regulator or a new combined unit?
PostPosted: Sat Aug 29, 2020 5:38 am
Combined unit.
PostPosted: Sat Aug 29, 2020 8:19 am
When I converted mini deluxe from generator to alternator I followed something like this
https://www.minimania.com/HOW__TO_CONVE ... ALTERNATOR
I ended up keeping the regulator in place and soldering the internals, but the principle would be the same. Should be a matter of connecting those wires and dropping the earth as outlined. (Assuming there isn’t anything else different on the uk wiring loom)
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Sat Aug 29, 2020 9:10 am
Thanks, switching from generator to alternator looks like a common mod. Ill give it a crack.
Users browsing this forum: No registered users and 117 guests
