Purchased wrong wiring loom https://www.ausmini.com/forums/viewtopic.php?f=2&t=100338 |
Author: | boostin86 [ Fri Aug 28, 2020 10:07 pm ] |
Post subject: | Purchased wrong wiring loom |
Purchased new wiring loom for Mini K / Mk 2 Copper S. Didn't state that it was for a Dynamo. Expected one for an alternator. What's involved to make it compatible ? Sent from my SM-G975F using Tapatalk |
Author: | winabbey [ Fri Aug 28, 2020 10:22 pm ] |
Post subject: | Re: Purchased wrong wiring loom |
boostin86 wrote: Purchased new wiring loom for Mini K / Mk 2 Copper S. Didn't state that it was for a Dynamo. Expected one for an alternator. What's involved to make it compatible ? In case you are thinking of returning it the Mini K and MK II S both had an alternator from first production, never a generator. If that's what the supplier was meant to supply and what it says on the package then they got it wrong. Can they fix it for you? |
Author: | boostin86 [ Fri Aug 28, 2020 11:03 pm ] |
winabbey wrote: boostin86 wrote: Purchased new wiring loom for Mini K / Mk 2 Copper S. Didn't state that it was for a Dynamo. Expected one for an alternator. What's involved to make it compatible ? In case you are thinking of returning it the Mini K and MK II S both had an alternator from first production, never a generator. If that's what the supplier was meant to supply and what it says on the package then they got it wrong. Can they fix it for you? Sent from my SM-G975F using Tapatalk |
Author: | timmy201 [ Sat Aug 29, 2020 5:36 am ] |
Ah well the UK MK2 still had a generator so that checks out. Are you using an original alternator with an external regulator or a new combined unit? |
Author: | boostin86 [ Sat Aug 29, 2020 5:38 am ] |
timmy201 wrote: Ah well the UK MK2 still had a generator so that checks out. Combined unit. Are you using an original alternator with an external regulator or a new combined unit? Sent from my SM-G975F using Tapatalk |
Author: | Andosoft [ Sat Aug 29, 2020 8:19 am ] |
When I converted mini deluxe from generator to alternator I followed something like this https://www.minimania.com/HOW__TO_CONVE ... ALTERNATOR I ended up keeping the regulator in place and soldering the internals, but the principle would be the same. Should be a matter of connecting those wires and dropping the earth as outlined. (Assuming there isn’t anything else different on the uk wiring loom) |
Author: | boostin86 [ Sat Aug 29, 2020 9:10 am ] |
Andosoft wrote: When I converted mini deluxe from generator to alternator I followed something like this Thanks, switching from generator to alternator looks like a common mod. Ill give it a crack. https://www.minimania.com/HOW__TO_CONVE ... ALTERNATOR I ended up keeping the regulator in place and soldering the internals, but the principle would be the same. Should be a matter of connecting those wires and dropping the earth as outlined. (Assuming there isn’t anything else different on the uk wiring loom) Sent from my SM-G975F using Tapatalk |
