Tacho reading wrong? https://www.ausmini.com/forums/viewtopic.php?f=2&t=10035 |
Author: | J_A_M [ Fri Aug 12, 2005 12:17 pm ] |
Post subject: | Tacho reading wrong? |
When driving JAM, I seem to be changing gear at 5000rpm, according to my tacho. It doesn't sound like the motor is doing 5000 rpm....so can a tacho be reading out? |
Author: | Harley [ Fri Aug 12, 2005 12:20 pm ] |
Well, if your tacho was set for a 6 or 8 cylinder (aftermaket one) car then it would read wrong, otherwise be thankful for a nice quiet engine. It'll get louder with age. Is it the stock tacho? Is the beast registered yet?? ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 12:25 pm ] |
I wouldn't bet on its accuracy, it's a Smiths... ![]() They all have pisspoor damping and jump around with the vibes of a Mini. Clubby one should not be miles out though, if reading steady. |
Author: | J_A_M [ Fri Aug 12, 2005 12:29 pm ] |
hmmmm.....its standard tacho and loom etc...only non standard is the dizzy and coil. Maybe I am taking it to 5000 each gear.....it does it with ease! ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 12:32 pm ] |
With the work your 1098 has, 5000 is a breeze. Don't believe all the BS from people that say 1098s don't rev and can't be made to. ![]() Vizard was wrong... ask GR. Or all the guys racing 1098 Sprites. ![]() |
Author: | CRU17Y [ Fri Aug 12, 2005 1:06 pm ] |
drmini in aust wrote: With the work your 1098 has, 5000 is a breeze. Don't believe all the BS from people that say 1098s don't rev and can't be made to.:
1098s do have the power, mine has great grunt for the little engine ![]() |
Author: | Harley [ Fri Aug 12, 2005 1:08 pm ] |
My 1100 loved to rev out. Fairly stock apart from sprite head and exhaust. Never struggled to get to 5000, but you sure knew about it from the noise. |
Author: | awdmoke [ Fri Aug 12, 2005 1:26 pm ] |
Post subject: | Re: Tacho reading wrong? |
J_A_M wrote: When driving JAM, I seem to be changing gear at 5000rpm, according to my tacho. It doesn't sound like the motor is doing 5000 rpm....so can a tacho be reading out?
Have you done a double check against the speedo? You know your diff ratio xx = ??kph @ 5000rpm It's probably OK, it's just running super sweet ![]() |
Author: | Lillee [ Fri Aug 12, 2005 1:40 pm ] |
I need to take you for a run in Lillee anton... She goes ballistic from 2500 to 5500 in very short time indeed! ![]() You can borrow my Fiat tacho if you want, it's very accurate ![]() |
Author: | gafmo [ Fri Aug 12, 2005 2:48 pm ] |
I wish Sue would allow me to put a Tacho in Morris ![]() |
Author: | Harley [ Fri Aug 12, 2005 3:02 pm ] |
Get a cheap digital one from an electronics shop, and mount it where it can't be seen except when its on. |
