what way up do the callipers go??? https://www.ausmini.com/forums/viewtopic.php?f=2&t=10050 |
Page 1 of 2 |
Author: | meeni [ Fri Aug 12, 2005 8:07 pm ] |
Post subject: | what way up do the callipers go??? |
hey guys, what way up do the brake callipers go on cooper s brakes? does the bleed nipple point up or down, or doesnt it matter? i hope somone knows! cheers sean |
Author: | EST-071 [ Fri Aug 12, 2005 8:17 pm ] |
Post subject: | Re: what way up do the callipers go??? |
meeni wrote: hey guys, what way up do the brake callipers go on cooper s brakes? does the bleed nipple point up or down, or doesnt it matter?
i hope somone knows! cheers sean commonsense would say the bleed nipples go to the top!! ![]() Pete |
Author: | JC [ Fri Aug 12, 2005 8:22 pm ] |
I'm not having a go at you Sean but you can't have built an entire car without a manual? |
Author: | minicranks [ Fri Aug 12, 2005 8:23 pm ] |
bleed nipples go at the top. |
Author: | benjamin [ Fri Aug 12, 2005 8:25 pm ] |
top cause the air rises ![]() |
Author: | Lillee [ Fri Aug 12, 2005 8:26 pm ] |
Nipples up top, air bubbles travel upwards so that's where you want to have your bleed nipple, otherwise air will always be trapped in the calliper |
Author: | TheMiniMan [ Fri Aug 12, 2005 9:01 pm ] |
oh you can mount them the other way up tho(,nipples pointing down,) Just that you`d have to take them off & hold them upside down to bleed them, them fit them back on for it all to work ![]() hee hee...i`m such the argumentative type ![]() see,,,if you were ever stuck with a broken caliper & you only had 2 left calipers or 2 right calipers, then you can still fit them up & they`ll work just fine, just that you`d have to bleed the odd one with the nipple pointing up , then fit it back on upside down at least someone might benefit from that usless trivia ![]() I`m so full of it hey? ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 9:05 pm ] |
TheMiniMan wrote: oh you can mount them the other way up tho(,nipples pointing down,)
Just that you`d have to take them off & hold them upside down to bleed them, them fit them back on for it all to work ![]() hee hee...i`m such the argumentative type ![]() see,,,if you were ever stuck with a broken caliper & you only had 2 left calipers or 2 right calipers, then you can still fit them up & they`ll work just fine, just that you`d have to bleed the odd one with the nipple pointing up , then fit it back on upside down at least someone might benefit from that usless trivia ![]() I`m so full of it hey? ![]() If upside down, just remember to put something between the pads when you bleed it off the car... I know someone on this board who has 2 LH ones.. anybody got 2 RH ?? ![]() ![]() |
Author: | TheMiniMan [ Fri Aug 12, 2005 9:19 pm ] |
I`ll swap you a left for a right ![]() I mean, your left for my right |
Author: | drmini in aust [ Fri Aug 12, 2005 9:23 pm ] |
I'll pass the message on when I see him. He's `out of the country'... but on this site... ![]() |
Author: | TheMiniMan [ Fri Aug 12, 2005 9:26 pm ] |
Oky Doky Docy ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 9:28 pm ] |
expect a PM.... ![]() |
Author: | TheMiniMan [ Fri Aug 12, 2005 9:30 pm ] |
Watch out or i will expect that PM , ,,,Don`t just dare me to expect that PM,.,,cause i`ll take you up on that dare & actually "read" that PM & probly even reply to it ![]() |
Author: | drmini in aust [ Fri Aug 12, 2005 9:31 pm ] |
Do tell.... ![]() |
Author: | Lillee [ Fri Aug 12, 2005 9:34 pm ] |
PM Sent already!!! ![]() |
