NLA Tapered washer for top door hinge to door. https://www.ausmini.com/forums/viewtopic.php?f=2&t=100669 |
Author: | drmini in aust [ Wed Jan 06, 2021 1:23 pm ] |
Post subject: | NLA Tapered washer for top door hinge to door. |
Attachment: IMG_20210106_152659.jpg These have been NLA for a while now.14A7387 is part number. According to my pub1052 parts list. 2 per door. I have just machined some alloy ones up, can do more if needed. Edit: Failure to fit this washer can result in distortion of the doorskin at the hinge. Price TBA but won't be expensive. |
Author: | cooperess [ Wed Jan 06, 2021 1:41 pm ] |
Post subject: | Re: NLA Tapered washer for top door hinge rear stud |
Is that part number 14A7387?? |
Author: | drmini in aust [ Wed Jan 06, 2021 2:06 pm ] |
My bad. It's on the rear hinge stud, and the front of door bolt, called distance piece. 2 per door. P/ no 14A7387. Will change part number on original post. Edit: The special washer mentioned ( item 17, but not shown) in parts list is a large diameter thin flat washer, it bends to fit the door skin curve. On rear stud only. |
Author: | Bubbacluby [ Wed Jan 06, 2021 7:15 pm ] |
Post subject: | Re: NLA Tapered washer for top door hinge to door. |
Available from minispares.... Bought a bunch in my last order. http://www.minispares.com/product/Class ... o%20search Well done though Doc |
Author: | cooperess [ Wed Jan 06, 2021 7:41 pm ] |
Minispares, look like they where made with a hacksaw. |
Author: | drmini in aust [ Wed Jan 06, 2021 7:52 pm ] |
Thanks guys. I looked here in Oz a while back, I think John Smidt had some but nobody else. |
Author: | cooperess [ Thu Feb 25, 2021 8:44 am ] |
There are NLA descibed as "Washer-special-rear servo top hinge" washers used on the door hinges, not sure where they fit or the dimensions, any help would be appreciated as I need some for my resto. |
Author: | winabbey [ Thu Feb 25, 2021 9:16 am ] |
https://minisport.com.au/mini-mk1-mk2-e ... led-spacer |
Author: | miniresto [ Thu Feb 25, 2021 9:34 am ] |
Agree with Cooperess. The photo of the ones on Minisport.com.au site look they were cut with a hacksaw by someone in a hurry! |
Author: | DavidE [ Thu Feb 25, 2021 1:57 pm ] |
drmini in aust wrote: My bad. It's on the rear hinge stud, and the front of door bolt, called distance piece. 2 per door. P/ no 14A7387. Will change part number on original post. Edit: The special washer mentioned ( item 17, but not shown) in parts list is a large diameter thin flat washer, it bends to fit the door skin curve. On rear stud only. Yes, 2 per door on the upper hinge and two per hinge mounting panel (the short part of the hinge) for these hinges as well. |
