It is currently Wed Jul 23, 2025 7:48 pm
PostPosted: Sun Feb 21, 2021 11:48 am
I stripped my doors many years ago to repaint them, now I have a problem remembering the order I should rebuild them.
Please give me the order remembering the door is bear.
PostPosted: Sun Feb 21, 2021 12:03 pm
A couple of helpful posts below. The first is for the Clubman style door but many things are common with your earlier version.
viewtopic.php?f=25&t=60640
viewtopic.php?f=25&t=69906
There's also a good article in one of the Workshop Manuals.
PostPosted: Sun Feb 21, 2021 12:19 pm
... and this thread - viewtopic.php?f=2&t=98916&p=1047714
Maybe timmy201 can send you a copy of the Gregory's pages about doors. My copy is elsewhere and not accessible.
PostPosted: Sun Feb 21, 2021 12:26 pm
I can email you a copy if you send me a PM with your email address. Might be later tonight by the time I can dig out the manual.
PostPosted: Sun Feb 21, 2021 4:07 pm
PM sent to timmy201. My doors are 1969 Mini.
PostPosted: Sun Feb 21, 2021 5:11 pm
If anyone wants the hard copy:
Gregory manual #64 covers round nose style roll up windows
Gregory manual #02 covers flappy handle doors 1971-1978 (inc late Mk2)
I think the “scientific publications” manual #64 is the same as the Gregorys but I’d have to double check
PostPosted: Sun Feb 21, 2021 5:50 pm
Yes both are the same book.
PostPosted: Mon Feb 22, 2021 12:42 pm
I forgot the chrome strips that hold felt/glass rubber and not mentioned in the manual. My tip is these go on first, then triangular piece goes in. The first door i put back together i left them until last, but they were a mongrel to get back on once 1/4 glass in place. I made it happen but it involved a block of wood, a hammer and much swearing :(
I also found the drivers door return spring was a pain. I looped 30cm string over the hook so i could pull it over the retaining screw.
I did mine over the xmas/new year break with plenty of time. When frustrated walked away rather than force anything, was much easier than previous times in the end.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
