It is currently Sun Aug 10, 2025 12:22 am
 Post subject: Bottom balls joints
PostPosted: Sat Aug 13, 2005 12:17 pm
Having great difficulty getting the bottom ball joint far enough into the arm to even get a thread to grab onto. Hole in the bottom arm looks too small for the ball joint to even go through. Is there a trick?
PostPosted: Sat Aug 13, 2005 12:46 pm
lf you have replaced the lower arm bushes you may have put the lower arms on the wrong side of the car. They are not interchangible.Just make sure the hole on the lower arm is wider at the top.
PostPosted: Sat Aug 13, 2005 1:27 pm
Success!!! You're a champion Chasg
