K&N Spin On Oil Filter https://www.ausmini.com/forums/viewtopic.php?f=2&t=100785 |
Author: | Wakka [ Sun Feb 21, 2021 5:16 pm ] |
Post subject: | K&N Spin On Oil Filter |
Folks, Forgive me if this has been posted before! For those who would prefer parts made somewhere other than China I found K&N oil filters at Supercheap. Made in the USA. As you might expect, 50% more expensive than Ryco. Ian |
Author: | DavidE [ Sun Feb 21, 2021 5:42 pm ] |
Post subject: | Re: K&N Spin On Oil Filter |
Good buys can be had on the likes of eBay. |
Author: | drmini in aust [ Sun Feb 21, 2021 5:47 pm ] |
I recently bought 4 Cooper (Chinese) oil filters on eBay. 2 leaked at the crimp. Also had 2 Ryco Z9s do the same. I've gone back to Wix (made in Poland). And Wix USA for the Z9s. |
Author: | mini0998 [ Sun Feb 21, 2021 6:42 pm ] |
I haven't used Ryco oil filters since I found metal shavings inside the filter. I also use Wix now (51348). Purchased a few last year and are made in USA. |
Author: | Phil 850 [ Sun Feb 21, 2021 8:41 pm ] |
https://www.wixfilters.com/About/PlantLocations.aspx Phil |
Author: | 9YaTaH [ Mon Feb 22, 2021 7:07 am ] |
mini0998 wrote: I haven't used Ryco oil filters since I found metal shavings inside the filter. I also use Wix now (51348). Purchased a few last year and are made in USA. Did you investigates why there were metal shavings in the filter? and did you thank Ryco for showing you that you had an engine problem ![]() |
Author: | winabbey [ Mon Feb 22, 2021 10:40 am ] |
mini0998 wrote: I haven't used Ryco oil filters since I found metal shavings inside the filter. New out of the box and before you had fitted it? |
Author: | mini0998 [ Mon Feb 22, 2021 4:23 pm ] |
Ryco filter was new out of the box. Went to lube rubber seal and there was a small metal filing sitting on rubber seal. Though mmmmmmm. Turned filter upside down and tapped it in the palm of my hand, couldn't believe what came out of the middle of the filter. Would say about 20 or so metal shavings. Not good. |
Author: | 9YaTaH [ Mon Feb 22, 2021 5:44 pm ] |
mini0998 wrote: Ryco filter was new out of the box. Went to lube rubber seal and there was a small metal filing sitting on rubber seal. Though mmmmmmm. Turned filter upside down and tapped it in the palm of my hand, couldn't believe what came out of the middle of the filter. Would say about 20 or so metal shavings. Not good. Hmmmmmm NOT GOOD...did you you report it to the supplier? RYCO website etc???? |
Author: | mini0998 [ Mon Feb 22, 2021 7:07 pm ] |
Took it back to supercheap, got a refund. They said they would follow it up but never heard back. |
Author: | TK [ Wed Feb 24, 2021 11:03 pm ] |
OMG |
Author: | Mick [ Thu Feb 25, 2021 11:52 am ] |
I wonder if some people think they can clean the K&N oil filter too... |
Author: | diecast [ Thu Feb 25, 2021 3:34 pm ] |
Funny you should mention cleaning K&N filters. I have had mine for a long time now and have never bothered to clean it. My reason being that Vizard tested a K&N air filter deeply covered in dust after one of those Baja desert races and it still flowed well compared to paper filters! |
