Radiator AAAHHKKK https://www.ausmini.com/forums/viewtopic.php?f=2&t=100864 |
Author: | Steam [ Mon Mar 29, 2021 8:49 pm ] |
Post subject: | Radiator AAAHHKKK |
The radiator in the paddock bomb has sprung a weeping leak. Nothing quite like replacing a mini radiator to fully test and squash the sense of humour. ![]() |
Author: | clip [ Wed Mar 31, 2021 3:54 pm ] |
Post subject: | Re: Radiator AAAHHKKK |
For a paddock bomb, it just needs a dose of pepper and leave rad cap lose. Drove like that for over 12 months in the old Hilux. |
Author: | Steam [ Wed Mar 31, 2021 4:37 pm ] |
clip wrote: For a paddock bomb, it just needs a dose of pepper and leave rad cap lose. Drove like that for over 12 months in the old Hilux. Is there a trick to it as I have never had it work for me. |
Author: | Kennomini [ Tue Apr 06, 2021 11:11 am ] |
Pepper floats so the water level needs to get down to the leak, then as the pepper flows out it gets stuck in the hole and seals it. Plus u need a fair bit sometimes if the leak is a distance away from the cap as the pepper may stick to the internals as it flows to the leak. |
Author: | Steam [ Tue Apr 06, 2021 2:40 pm ] |
Yeah. I think I will just replace the rad. |
Author: | Kennomini [ Wed Apr 07, 2021 11:27 am ] |
Good choice |
Author: | Steam [ Thu Apr 08, 2021 8:40 am ] |
What started out as a slight weep developed into a full scale deluge when running the engine to do the mixture. I ended up standing in water on the shed floor. So I decided to open the can of worms, the T/stat housing was crumbling, one of the bolts sheared and the lower cowl fell to bits. I now have a 1/4 inch sheared bolt to play with. You gotta love a mini don't you. ![]() ![]() ![]() |
Author: | Kennomini [ Sat Apr 10, 2021 11:59 pm ] |
On the bright side, now you have started you'll have a fully rebuilt mini in about 10 years, so long as you stick to the "while I'm in there" mentality. |
