SU Carby Part https://www.ausmini.com/forums/viewtopic.php?f=2&t=101056 |
Author: | cooperess [ Thu Jul 15, 2021 3:02 pm ] |
Post subject: | SU Carby Part |
Attachment: 1877.jpg I need the alloy plate that goes onto float bowl lid that covers the overflow hole. I know there must be thousands of these but I can't find the part number or description.
Author: | gtogreen1969 [ Thu Jul 15, 2021 3:48 pm ] |
Post subject: | Re: SU Carby Part |
cooperess wrote: Attachment: 1877.jpg I need the alloy plate that goes onto float bowl lid that covers the overflow hole. I know there must be thousands of these but I can't find the part number or description.AUC1215 |
Author: | TDS76 [ Thu Jul 15, 2021 3:55 pm ] |
I also need one. It is called a vent baffle and the part no. is AUC1215. If you find one at a reasonable price, let me know. The best I have found in Oz is $9.01 + 14.50 shipping. Cheers, Paul. |
Author: | DavidE [ Thu Jul 15, 2021 3:58 pm ] |
cooperess wrote: Attachment: 1877.jpg I need the alloy plate that goes onto float bowl lid that covers the overflow hole. I know there must be thousands of these but I can't find the part number or description.It is called a Baffle Plate. More than that I don't know. Have you quizzed Burlen, or at least Midel? Edit: It is AUC1215. Google that for suppliers. |
Author: | ben73 [ Thu Jul 15, 2021 5:22 pm ] |
I might have one, will check on Saturday |
Author: | DavidE [ Thu Jul 15, 2021 5:39 pm ] |
ben73 wrote: I might have one, will check on Saturday I will have more than some as well, but the OP hasn't made clear what he is after. |
Author: | cooperess [ Thu Jul 15, 2021 9:17 pm ] |
Baffle Plate, AUC1215. Great work guys. Now to do some hunting. |
Author: | 1970cooper [ Fri Jul 16, 2021 5:04 am ] |
Please correct me if I am wrong,but doesn't the fuel still come out of the vent with baffle fitted if the float is not shutting off the fuel.Is the idea of the baffle to make the fuel come straight down instead of spraying everywhere? |
Author: | timmy201 [ Fri Jul 16, 2021 6:06 am ] |
I think it’s just to direct the overflow downwards rather than spraying in a fine stream in the direction of the hole. You can also get the later fuel bowl lids that accept a hose, that was you can put the hose away from the hot exhaust |
Author: | 1970cooper [ Fri Jul 16, 2021 7:10 am ] |
Thanks for info Timmy.I did have fuel coming out in that area a few months ago and I found the float stuck. I do not know if i have a baffle fitted to mine,I will check later. |
Author: | cooperess [ Fri Jul 16, 2021 8:49 am ] |
DavidE wrote: It is called a Baffle Plate. More than that I don't know. Have you quizzed Burlen, or at least Midel? Edit: It is AUC1215. Google that for suppliers. Just quizzed both of the above and found the part DavidE, thank you. Maybe someone has a few these laying around they would like to pass on! |
Author: | cooperess [ Sun Jul 18, 2021 3:20 pm ] |
Found. |
