Couple of questions about my cooper s https://www.ausmini.com/forums/viewtopic.php?f=2&t=101160 |
Author: | carter [ Fri Dec 31, 2021 4:45 pm ] |
Post subject: | Couple of questions about my cooper s |
Just a couple of questions.....what colour is the generator and starter motor supposed to be on a mk 1 s and also what colour interior mirror ? Thanks in advance for the replies. |
Author: | gtogreen1969 [ Fri Dec 31, 2021 5:21 pm ] |
Post subject: | Re: Couple of questions about my cooper s |
carter wrote: Just a couple of questions.....what colour is the generator and starter motor supposed to be on a mk 1 s and also what colour interior mirror ? Thanks in advance for the replies. Genny and starter were painted metallic green with the rest of the donk. Mirror was a greyish colour but I don't know the name. It might be in the tech drawing. |
Author: | carter [ Fri Dec 31, 2021 6:03 pm ] |
no worries, I thought as much but wasn't sure about the interior mirror. I have the one your talking about so that's good. I saw a black one the other day and made me not too sure. |
Author: | gtogreen1969 [ Fri Dec 31, 2021 6:11 pm ] |
The crackle black mirror was used in 1965 and 1966. Not sure of the change point. Here is a pic of the 2 types Attachment: Early crackle black Vs later grey mirror.jpg
Author: | carter [ Fri Dec 31, 2021 9:52 pm ] |
Thanks very much gto appreciate it |
Author: | eightfifty [ Sat Jan 01, 2022 6:50 pm ] |
Author: | gtogreen1969 [ Sat Jan 01, 2022 8:34 pm ] |
eightfifty wrote: The drawing for the later mirror shown above is dated August 1965, which means it probably went into production some months after that. The finish is specified as consisting of 1 coat of 2 pack zinc chromate etch primer, and top coat of stoving enamel which is a high gloss finish. Alas, the actual colour is not specified, but the same mirror is used for Mini Minor, Deluxe and Cooper S of the time. Interestingly, the bracket is made from die cast aluminium (hence the etch primer) and the mirror back from 0.02" steel. The ball (plastic) is a separate part which presses on to a stub at the end of the bracket. Thanks for the info. I just checked through my pics of period photos and unrestored cars and it looks like the mirror change was Oct/Nov 1966. |
Author: | cooperess [ Sat Jan 01, 2022 9:06 pm ] |
eightfifty wrote: The drawing for the later mirror shown above is dated August 1965, which means it probably went into production some months after that. The finish is specified as consisting of 1 coat of 2 pack zinc chromate etch primer, and top coat of stoving enamel which is a high gloss finish. Alas, the actual colour is not specified, but the same mirror is used for Mini Minor, Deluxe and Cooper S of the time. Interestingly, the bracket is made from die cast aluminium (hence the etch primer) and the mirror back from 0.02" steel. The ball (plastic) is a separate part which presses on to a stub at the end of the bracket. Are you able to show the drawing mentioned? |
Author: | carter [ Sat Jan 01, 2022 9:08 pm ] |
Thanks for all the info. The knowledge base here is amazing. |
Author: | Bill B [ Sat Jan 01, 2022 10:38 pm ] |
My Mk1 is body number 1197 and, according to the Ausmini register, was made around April, 1966. It has the light grey later-style mirror. Considering that internal rear vision mirrors were rarely targeted for aftermarket customising, I suspect the mirror in my car could be the original and so these may have been fitted a bit earlier than has been suggested here. |
Author: | eightfifty [ Sun Jan 02, 2022 8:21 am ] |
Author: | cooperess [ Sat Apr 15, 2023 11:36 am ] |
Attachment: Mini Rear View Mirror Ball Joint Repair DSCF0649.JPG Is there someone who can make or has ball to replace my almost broken ball - see arrow. |
Author: | eightfifty [ Sat Apr 15, 2023 12:15 pm ] |
Yes, I have a stock of the correct balls, but you have to take the whole thing apart - that is, remove the glass from the metal housing, to install the ball (instructions supplied) and then put the glass back in afterwards. If you write to me by email with your address, I'll send you one. Don't send a message via ausmini, I don't check these messages. regards, Tony |
Author: | cooperess [ Mon Apr 24, 2023 11:49 am ] |
Thank you eightfifty (Tony) for the fix for my rear vision mirror. |
