Mike wrote:
Clicking would usualy suggest that it is working. Just whack a test bulb on it or something, and make sure its earthed properly. Btw, its very possible that the terminal on your starter motor has gone loose and is either shorting out on its casing or is just not connected to the brushes.
When solenoids get old, they click and no go. This is because the high starter current arcs the copper contacts and with time eventually wears them away. The solenoid armature pulls in still but it runs out of travel before making proper contact.
I know this, `coz I've pulled a few Lucas ones apart and made short term fixes..
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
