It is currently Sat Jul 19, 2025 10:36 am
 Post subject: Door Rubbers
PostPosted: Mon Jul 25, 2022 2:06 pm
I have a 1964 mk1 which was originally a sliding window car - but at some point the doors were replaced with Deluxe type doors.
I have always had issues with door rubbers and doors closing correctly (I am using NON 850 door rubbers). I am aware of the 2 different types of door rubbers available.
Are the different rubbers due to the shape of the doors or are the door apertures a different shape? (hopefully that makes sense)
I am considering using the smaller 850 door rubbers... I am interested to hear from anyone that is more knowledgeable than I about the doors, rubbers and apertures.
Thanks mini'ers
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: Door Rubbers
PostPosted: Tue Jul 26, 2022 9:13 am
I found out that UK MK 1 850 door rubbers don't work with Mini K/Matic windup doors. After importing them.
I had a 3mm gap in places.
Not sure if it's the door or body flange different.
PostPosted: Tue Jul 26, 2022 11:20 am
Thanks Doc...
This is what i was trying to work out.. I need to replace the door rubbers, i would rather just not have to buy 2 different sets.
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Jul 26, 2022 6:15 pm
Take the door rubbers off and check the clearance between door and body, where there is a tight clearance use a hammer and block of wood to bend the body flange in towards the Centre of car. This will help but you may have to try the smaller rubber that is available .Rod Martin would know I will send you his number.
Allen
Users browsing this forum: Google [Bot] and 110 guests
