It is currently Sat Jun 28, 2025 11:15 pm
PostPosted: Mon Sep 12, 2022 6:02 pm
Did BMC have two versions of the metal pipe at the engine end. Here is what I have.
PostPosted: Mon Sep 12, 2022 9:20 pm
and if its okay how does this actually go from engine to gauge? i have the metal piece but obviously not long enough to go to gauge.... dont mean to hijack thread.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Mon Sep 12, 2022 9:44 pm
carter - There is a rubber hose and then metal tube.
PostPosted: Mon Sep 12, 2022 11:17 pm
This is what the 2 pipes and hose look like
Yours should look something like this
PostPosted: Tue Sep 13, 2022 8:37 am
Thank you gtogreen1969
Re the hose I replaced mine last year. But found the new hose poor quality and the clamps too.
Instead of 1/8" hose I then bought 3mm fuel injection hose it's a nice tight fit on the pipe barbs.
PostPosted: Tue Sep 13, 2022 8:42 am
Now to get things back on track.
Did BMC have two versions of the metal pipe at the engine end (please see first picture)?
PostPosted: Tue Sep 13, 2022 10:09 am
Mini King's catalogue shows only 1 version p/n CAM4202.
The top tube looks to be about the correct length. The tubes can be easily damaged, which might explain what happened to the shorter one and it has been modified to suit.
PostPosted: Tue Sep 13, 2022 10:38 am
PostPosted: Tue Sep 13, 2022 3:26 pm
Pipe at bottom of picture (shorter pipe) = engine > rubber (interconnect) hose. However I believe the 'slotted' clip (pictured on the longer length) goes over this shorter pipe. This clip is held in place via the 5/16" UNC flywheel housing bolt adjacent to the oil union outlet. The 'P' clip goes on the longer length of pipe, held via the 1/8" BSW nut to the screw securing (in your case) dash nacelle.
PostPosted: Tue Sep 13, 2022 4:24 pm
This pic of my MK II S prior to restoration showing the metal pipe to the gauge and the securing clip. Obviously the pics posted earlier by gtogreen1969 are a Mark 1 Cooper S with the earlier white plastic instrument binnacle behind the oval binnacle.
PostPosted: Wed Sep 14, 2022 4:15 pm
So Doug, the pipe is held to the firewall by a screw that holds the oval binnacle in?
PostPosted: Wed Sep 14, 2022 7:12 pm
Yes
PostPosted: Wed Sep 14, 2022 9:03 pm
Just compared your picture with my Mk2 and can see there is a difference between our Mini's. My firewall has a nut welded to the firewall so there is no way the oil pipe can fit like yours.
PostPosted: Wed Sep 14, 2022 9:23 pm
That screw is longer to fit the extra P clip and nut.
