It is currently Thu Jul 17, 2025 12:51 am
 Post subject: mk 2 cs speedo
PostPosted: Wed Oct 12, 2022 3:40 pm
Hello All ,
The speedo dial bounces at low speeds as it gets to 40 or over the dial is steady, anyone had this problem ?
Allen
 Post subject: Re: mk 2 cs speedo
PostPosted: Wed Oct 12, 2022 5:10 pm
Could it have something to do with a 310 cam and touchy clutch? - apologies I am no help on this matter
PostPosted: Wed Oct 12, 2022 5:56 pm
I had that problem. The gauge shop supplied me a new speedo cable, they said some of them have the nylon guide in the speedo end off centre, which can cause the low speed wobble
PostPosted: Thu Oct 13, 2022 9:34 am
If timmy201's suggestion isn't the issue, could it possibly be the return spring losing a bit of its original tension in the low speed range, after all these years?
PostPosted: Thu Oct 13, 2022 9:54 am
A new cable would be the simplest and cheapest thing to rule out..
PostPosted: Thu Oct 13, 2022 5:31 pm
Thanks ,I will get a new cable I bought the speedo for $350. not working and spent
$400 for reco 2 years ago.
Allen
PostPosted: Thu Oct 13, 2022 5:36 pm
I had the same problem as yours. Replaced with new speedo (wanted to do that anyway), and new inner speedo cable. Made no difference, but just today I fitted new complete speedo cable and it’s now perfect.
