mk 2 cs speedo
https://www.ausmini.com/forums/viewtopic.php?f=2&t=101564
Author:  p7676 [ Wed Oct 12, 2022 3:40 pm ]
Post subject:  mk 2 cs speedo
Hello All ,
The speedo dial bounces at low speeds as it gets to 40 or over the dial is steady, anyone had this problem ?
Allen
Author:  FNQ [ Wed Oct 12, 2022 5:10 pm ]
Post subject:  Re: mk 2 cs speedo
Could it have something to do with a 310 cam and touchy clutch? - apologies I am no help on this matter
Author:  timmy201 [ Wed Oct 12, 2022 5:56 pm ]
I had that problem. The gauge shop supplied me a new speedo cable, they said some of them have the nylon guide in the speedo end off centre, which can cause the low speed wobble
Author:  Bill B [ Thu Oct 13, 2022 9:34 am ]
If timmy201's suggestion isn't the issue, could it possibly be the return spring losing a bit of its original tension in the low speed range, after all these years?
Author:  simon k [ Thu Oct 13, 2022 9:54 am ]
A new cable would be the simplest and cheapest thing to rule out..
Author:  p7676 [ Thu Oct 13, 2022 5:31 pm ]
Thanks ,I will get a new cable I bought the speedo for $350. not working and spent
$400 for reco 2 years ago.
Allen
Author:  clip [ Thu Oct 13, 2022 5:36 pm ]
I had the same problem as yours. Replaced with new speedo (wanted to do that anyway), and new inner speedo cable. Made no difference, but just today I fitted new complete speedo cable and it’s now perfect.
