1969 mini k
https://www.ausmini.com/forums/viewtopic.php?f=2&t=101571
Author:  p7676 [ Wed Oct 19, 2022 11:27 am ]
Post subject:  1969 mini k
Syncro gone on second gear, what's a ball park figure to get it fixwd ?
Allen
Author:  timmy201 [ Wed Oct 19, 2022 12:11 pm ]
Post subject:  Re: 1969 mini k
I guess it depends a lot on how much you do yourself
Dropping off a running car for the job will obviously add a lot of time and money in labour
If you did it all yourself and only replaced the synchro ring, it’d be a couple hundred once you take into account the gaskets, oil, coolant etc. There’s a decent chance that other things will need to be replaced while it’s apart and most shops won’t put it back together unless it’s all rebuilt and warrantable
Author:  surtees [ Wed Oct 19, 2022 1:25 pm ]
Agree with Timmy, It's a bit of how longs a piece of string. Even doing it yourself once you get it open what else you find.
Author:  p7676 [ Wed Oct 19, 2022 4:04 pm ]
OK thanks ,it is not my car ,what would a rebuilt box cost including all labor and parts ?
Allen
Author:  i got a mini [ Wed Oct 19, 2022 7:57 pm ]
i have herd of gear boxes costing upwards of 3000
Author:  Andosoft [ Thu Oct 20, 2022 8:30 am ]
I handed my gearbox to a reputable mini rebuilder 18mths ago. It was already clean and all new bearings, layshaft & laygear (NOS) supplied. He replaced 1st gear, all baulk rings, thrust washers and it was around the $1300 region not including diff or gasket sets. So mostly labour (and by labour i mean knowledge), and a job well done i was happy to pay it even though I could have done it myself.
But that was my scenario, and i would suggest that would be a ball park minimum. If they are pulling the engine and find other things you can start multiplying that number by 3,4,5…. As Timmy suggests it would be a false economy to not check other things while the engine is out & split.
