Fuel Feed Pipe Positioning https://www.ausmini.com/forums/viewtopic.php?f=2&t=101617 |
Author: | cooperess [ Sun Dec 04, 2022 4:46 pm ] |
Post subject: | Fuel Feed Pipe Positioning |
Attachment: Mini Fuel Feed Pipe DSCF1594 (2).JPG Attachment: Mini Fuel Feed Pipe DSCF1594 (1).JPG Attachment: Mini Fuel Feed Pipe DSCF1594 (3).JPG Just would like to know the correct positioning of the twin SU carby fuel feed pipe. |
Author: | ausdino [ Sun Dec 04, 2022 7:04 pm ] |
Post subject: | Re: Fuel Feed Pipe Positioning |
Rightly or wrongly so, mine is #2 with another strap going around the pipe and secured by the accelerator cable bracket nut. |
Author: | gtogreen1969 [ Sun Dec 04, 2022 10:58 pm ] |
Yeh run the fuel pipe closest to the rocker cover. There is a short P clip that supports the fuel pipe at the PCV valve and another longer P clip at the other end. The Accelerator Cable bracket goes on first then the short P clip then the PCV valve bracket. Here are some pics if needed Attachment: PCV setup.jpg Attachment: Fuel Pipe Long P clip.jpg
