It is currently Sat Jul 19, 2025 1:41 am
 Post subject: Paper air filter for HS6
PostPosted: Mon Dec 12, 2022 10:03 pm
I have done a lot of searching but I haven't found a paper type filter for a HS6 that will fit in a mini. Is there something I haven't found?
I want to use a paper filter as my mini will get driven to a place which has lots of red dust, for a while we basically had a machine that made dust due to no water supply. I have a few ideas for custom housings or a Donaldson filter but the Donaldson does sound a little bit restrictive for the amount I will drive it in the city.
Test... Don't Guess
PostPosted: Mon Dec 12, 2022 10:14 pm
Try google.....https://www.rendcarparts.com/volvo/part ... 1/RD672281
PostPosted: Mon Dec 12, 2022 10:32 pm
Interesting. I hadn't actually tried googling it for a while and haven't seen that before. Would that actually fit though?
Test... Don't Guess
PostPosted: Tue Dec 13, 2022 8:21 am
Its pretty easy to make your own filter case.
I used basic hand tools and some scrap alloy sheet to make a top and bottom plate to sandwich an XU1 paper filter. I made two to fit my twin HS4s so a single would be half the work :)....
The Holden filters also provide plenty of room for some after market stub stacks.
Cheers, Ian
