It is currently Sat Jul 19, 2025 2:54 am
 Post subject: Boot Board Brackets.
PostPosted: Sat Dec 17, 2022 8:47 am
Can someone help me out with the location of the 3 boot board brackets found onthe cooper s - so RH tank model. I'm pretty sure the middle bracket with the rubber insert is located centrally in the aperture but just need the offsets to the other two. Cheers,
 Post subject: Re: Boot Board Brackets.
PostPosted: Sat Dec 17, 2022 3:34 pm
See photo, can provide measurements, if you wish. Not a symmetrical arrangement.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Dec 17, 2022 6:12 pm
Awesome, thanks CGO, I do like a good measurement.. if you wouldn’t mind. It appears that the offside one lines up with the middle of the boot hinge, and the near side one is on the inner edge of the boot hinge.. (I don’t have a boot board at the moment, or a RH fuel tank)
PostPosted: Sat Dec 17, 2022 7:01 pm
I hope these are of some use, shell is on rotisserie at the moment and upside down.
* Rhs rivet is 15mm to left of Rhs boot hinge centre between bolt holes
* Middle mount is 215mm to left of Rhs rivet or 230mm left of Rhs boot hinge centre between bolt holes
* Lhs rivet is 53mm to left of Lhs boot hinge centre between bolt holes
PostPosted: Sat Dec 17, 2022 7:21 pm
Perfect! Awesome, problem solved.. thanks all, much appreciated.
