Remote shifter hole
https://www.ausmini.com/forums/viewtopic.php?f=2&t=101629
Author:  TK [ Sat Dec 17, 2022 7:54 pm ]
Post subject:  Remote shifter hole
Putting a remote shifter into an 850. Anyone got any measurements or even just a photo?
Author:  gtogreen1969 [ Sat Dec 17, 2022 8:44 pm ]
Post subject:  Re: Remote shifter hole
56 cm to 65 cm from the passenger door sil
4 cm to 16 cm forward of crossmember
I would cut it a bit smaller to start with then test and adjust as needed
56 - 65 cm from the passenger door sil. 4 - 16 cm forward, Remote floor hole.png
Author:  TK [ Sat Dec 17, 2022 8:57 pm ]
Thank you so much.
Author:  andrew9 [ Sun Dec 18, 2022 8:58 pm ]
How difficult is it to fit a remote shifter in an 850 with a RC40, while keeping the starter button?
Author:  IndigoBlueCooperS [ Sun Dec 18, 2022 10:01 pm ]
Have the remote shifter, RC40 (1&7/8?) and 850 push button start in my Monaco which is based on a 62 850.
Made sure the battery cables had the lugs on the best way to keep them away from the exhaust.
No problems with it.
Author:  timmy201 [ Mon Dec 19, 2022 8:05 am ]
I had to give the exhaust pipe a bit of a hit with the hammer to give clearance. With the exhaust tucked up a bit more it had made contact before I added the divot
