Diff, gearbox or primary gear noise
https://www.ausmini.com/forums/viewtopic.php?f=2&t=101694
Author:  clip [ Wed Feb 01, 2023 11:13 pm ]
Post subject:  Diff, gearbox or primary gear noise
Been thinking about this for a while now, hoping someone can help (although I probably should know myself), my original 850 engine (reconditioned and in good condition) but it has this very loud whine. I remember my first mini, also an 850 was a bit whiny too, but nothing like this. You can hear it really clearly in this clip if you jump to near the end around 5:50 where it’s taken from outside the car. It was really loud inside though and through every gear under load - both backing off and accelerating. Just wondering if it’s diff, gearbox bearing somewhere, or primary gear. I would normally say diff, but not sure on the mini.
https://youtu.be/Nb0IUrY0u-w
Author:  drmini in aust [ Thu Feb 02, 2023 4:57 am ]
Post subject:  Re: Diff, gearbox or primary gear noise
Idler gear would be my bet. If its bearings go they can destroy the gearbox case or flywheel housing.
Author:  clip [ Thu Feb 02, 2023 1:47 pm ]
Thanks drmini, the engine is out so will have to do a strip down, but at least I’ll know where to start. Big learning curve coming up for me.
