Reverse light yes or no 1968 https://www.ausmini.com/forums/viewtopic.php?f=2&t=101695 |
Author: | surtees [ Thu Feb 02, 2023 3:20 pm ] |
Post subject: | Reverse light yes or no 1968 |
Hi All, As the topic says does a 1968 Mini require a reverse light? From what I can find, I think no as ADR's came in from the 1st of Jan 69. So just like rear seat belts or amber front indicator lens, I don't have to have a reverse light. There isn't a reverse switch on my trans under the oil filter or on the shift mechanism. Is my thinking correct? |
Author: | drmini in aust [ Thu Feb 02, 2023 3:30 pm ] |
Post subject: | Re: Reverse light yes or no 1968 |
Reversing lights January 1972 I think. My 5/70 Matic has none, my friend's late 71 Cooper S with the clubby doors, does. |
Author: | Barkfast [ Thu Feb 02, 2023 3:31 pm ] |
My 1969 Mini K does not have reverse lights. Looking at the ADR page - it looks like they were required from 1972? https://www.infrastructure.gov.au/infra ... nd-edition |
Author: | winabbey [ Thu Feb 02, 2023 3:32 pm ] |
surtees wrote: Hi All, As the topic says does a 1968 Mini require a reverse light? From what I can find, I think no as ADR's came in from the 1st of Jan 69. So just like rear seat belts or amber front indicator lens, I don't have to have a reverse light. There isn't a reverse switch on my trans under the oil filter or on the shift mechanism. Is my thinking correct? Your thinking is correct. No reverse lamps required. ADR 1 - Reversing Signal Lamps was effective from Jan 1972. https://www.infrastructure.gov.au/infra ... nd-edition Some Minis were fitted with reversing lights on the assembly line prior to that but as a special option. For example, NSW Police vehicles specified them. |
Author: | surtees [ Thu Feb 02, 2023 3:41 pm ] |
Thanks all thought that was the case, just couldn't find good links on the VIC roads website. |
