Heater plastic body type https://www.ausmini.com/forums/viewtopic.php?f=2&t=101714 |
Author: | crisonic [ Sat Feb 11, 2023 9:59 am ] |
Post subject: | Heater plastic body type |
Does anybody have dimension details of the fitting that connects the heater outlets to the screen heater hoses on the plastic bodied heater box? A picture of this would be of some help I assume it is some sort of plastic fitting. Many thanks |
Author: | Steam [ Sat Feb 11, 2023 12:07 pm ] |
Post subject: | Re: Heater plastic body type |
Is this what you mean The smaller end is 55mm od The larger end is 61mm od Measiring around the outer curve is 140mm Inner middle to larger outer is 45mm Inner middlie to smaller end is 40mm |
Author: | crisonic [ Sat Feb 11, 2023 2:20 pm ] |
Thank you so much. I had assumed it was a straight fitting.Just complicates the making of the part. |
Author: | timmy201 [ Sat Feb 11, 2023 6:17 pm ] |
I’m sure there’s a lot gathering dust in sheds, a wanted post might find you a pair |
Author: | crisonic [ Mon Feb 13, 2023 11:10 am ] |
Thanks Timmy I will have a go but will try Brian at Link first |
Author: | i got a mini [ Fri Feb 17, 2023 9:32 pm ] |
if you get stuck i can 3d print you one no problem |
