camshaft questions
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10180
Author:  Flying Brick [ Tue Aug 16, 2005 10:01 am ]
Post subject:  camshaft questions
Gday everyone,
I have 2 camshafts, both out of 1275's(apparently).I can't find any numbers on them to identify them. One of them has a lobe for the fuel pump and the other has no lobe which would be ok if it was put in an engine with a electric pump. Is this normal for some not to have the lobe? I havn't seen this before. Both have different oil pump drives too.
Thanks.
Steve.
Author:  feralsprint [ Tue Aug 16, 2005 10:17 am ]
The one without the lobe is probably a Cooper S cam and from my fading memory they also used a series or rings around the cam to identify what cam it is, the other cam is probably an 1100S cam shaft, the other give away is the width of the lobes
Jon
