Mk1 Steering column clocking https://www.ausmini.com/forums/viewtopic.php?f=2&t=101860 |
Author: | MINIRO [ Mon May 22, 2023 2:01 pm ] |
Post subject: | Mk1 Steering column clocking |
The indicator cancelation screw on a mk1 steering column, where should this clock? My steering wheel is not sitting where it should be, so I would like to remove and replace the column, but making sure it is correctly clocked. Thank you |
Author: | 68+86auto [ Mon May 22, 2023 2:08 pm ] |
Post subject: | Re: Mk1 Steering column clocking |
The column can only go on one way on most minis. In the central/straight position the clamping bolt should be horizontal at the bottom. The steering wheel should be level in this position. |
Author: | MINIRO [ Mon May 22, 2023 2:50 pm ] |
68+86auto wrote: The column can only go on one way on most minis. In the central/straight position the clamping bolt should be horizontal at the bottom. The steering wheel should be level in this position. Thank you. I haven't pulled a column on a mk1 before. So this is good info to know. |
Author: | timmy201 [ Mon May 22, 2023 3:02 pm ] |
As mentioned above, pinch bolt horizontal Then make sure the wheel is on straight Then line up the outer column so that the cancelling peg on the column lines up with the centre of the indicator stalk. |
Author: | 1071 S [ Mon May 22, 2023 9:51 pm ] |
If the steering wheel is not on straight then maybe it needs to removed from the column and corrected?? No need to move the column unless there is another problem. Cheers, Ian |
