It is currently Fri Jul 18, 2025 10:41 pm
 Post subject: Handbrake bracket repair
PostPosted: Mon Jul 17, 2023 7:55 pm
Hi all,
Any ideas the best way to fix this? The metal around the front hole has torn
I see the bracket is available new as 14A6669
PostPosted: Mon Jul 17, 2023 8:14 pm
you could weld a washer on it as an easy fix?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Mon Jul 17, 2023 10:15 pm
Hi Timmy, I have one of them (14a6669). I feel your pain. Mine must have been pulled off the floor. They then butchered/repaired it with small bolts and self tappers. I will have to weld up the holes in the tunnel, reshape the tunnel where it has been deformed at the rear of the bracket area and puddle weld the new one in. Too many handbrake turns its past before me .....
PostPosted: Tue Jul 18, 2023 9:00 am
I've never seen one do that, but every Mini or Moke that I've owned has had something wrong where that bracket attaches to the floor. Its quite interesting when you pull up the hand brake to release it and it peels up a chunk of floor.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Jul 18, 2023 11:24 pm
It is very common on mini's and mokes that have done motor khanas or a bit of rallying
PostPosted: Wed Jul 19, 2023 2:28 pm
You could possibly weld some washers either side of the bracket, but at this point it is probably easier to replace the whole thing if you have to remove the carpet etc.
67 Van, 1275cc
PostPosted: Thu Jul 20, 2023 2:14 pm
I cut a little bit of 25mm x 25mm x 3mm angle iron and bolted it to the floor, with a panel washer underneath - the old, broken bracket is just sandwiched between the handbrake and the angle
PostPosted: Mon Jul 24, 2023 8:22 pm
Thanks all for the advice. I don't have a welder so I needed to get the carpet out to get a better look & potentially prepare it for someone else to weld in a new bracket.
The section that tore had already been welded, and the edge that meets the crossmember had also been rewelded
I figured there was nothing to lose by cutting off the torn section and drilling a new hole. It did move the handbrake lever down 1/2" or so, but still useable. At least when I decide to get the whole bracket replaced in the future I haven't modified the tunnel
PostPosted: Mon Jul 24, 2023 10:03 pm
Well done.
