1969 Fuel Cap Seal Replacement 21A2109 https://www.ausmini.com/forums/viewtopic.php?f=2&t=101995 |
Author: | cooperess [ Sun Aug 27, 2023 11:51 am ] |
Post subject: | 1969 Fuel Cap Seal Replacement 21A2109 |
I have tried the current version (rubber type) and they are useless. They curl up and the car has only had fuel in it for a month. Is there a better alternative, such as the original cork type seal and where can I get them. Attachment: Mini Fuel Cap Gasket 21A2109 DSCF2094.JPG
Author: | DavidE [ Sun Aug 27, 2023 11:55 am ] |
Post subject: | Re: 1969 Fuel Cap Seal Replacement 21A2109 |
Make one out of sheet cork. |
Author: | cgo [ Sun Aug 27, 2023 12:52 pm ] |
Took cap with me to local Bunnings plumbing section. Found this rubber seal, been on car for 4 years. Better quality rubber than expected. |
Author: | Barkfast [ Tue May 28, 2024 11:14 pm ] |
Found my fuel caps were leaking fuel, so decided to try out CGO recommendation of a toilet cistern washer. The washer that seemed to fit the dimensions were for Johnson and Suisse systems. Here's a link https://www.bunnings.com.au/kinetic-bla ... r_p4920270 The washers are thicker than 2.x mm rather than 1.4mm, but with a little grease around the lip of the tank they fit ok. Thought it would might be useful to share incase it helps. |
Author: | simon k [ Wed May 29, 2024 10:06 am ] |
That is interesting - I have a few of those washers.. I'm using fuel caps that were for a valiant or something, they've lasted really well. |
