It is currently Wed Jul 09, 2025 8:35 am
PostPosted: Mon Oct 02, 2023 9:17 pm
Hi guys,
Prompted by the wanted post and same on the mk1 forum, I had a look at what I had.
I knew I didn't have the originals, and had bought two of the reproductions.
The repros don't hold the air box tight even after running a die down the elbow thread without cutting more thread, and don't look like pictures of the originals.
I have three of the longer ones for the single air boxes I can shorten in the lathe and re tap.
Can anybody help me with the dimensions.
Thanks in advance
Stewart
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Tue Oct 03, 2023 9:25 pm
Hello Stewart,
I gave it a go for you. I measured one I've got here and I get 30mm from under the head to the end of the tube. The length of the thread measured 16mm
Regards,
Glen
PostPosted: Wed Oct 04, 2023 5:51 am
Here’s some we prepared earlier
viewtopic.php?p=996223#p996223
PostPosted: Wed Oct 04, 2023 5:00 pm
Sorry, I didn't realise the subject had been covered in 2016
Glen
PostPosted: Wed Oct 04, 2023 5:30 pm
Glen
It was one of our reoccurring conversations in our local mini group for a while and it’s burned in my brain :lol:
PostPosted: Wed Oct 04, 2023 6:28 pm
Thanks Guys, I had read the topic Timmy posted but to be honest I was still confused as to which of those pictured referred to a 1966 cooper S.
Apologies if I've been obtuse, a lot going on in my aging brain at the moment.
Thanks Stewart
Mk 1 Cooper S 1965
PostPosted: Wed Oct 04, 2023 6:57 pm
I believe the 1966 S should have the one on the left
Left: Shank = 30mm / Diameter = 8.8mm
PostPosted: Wed Oct 04, 2023 8:59 pm
Thanks Timmy I'll compare it with the long ones I have.
Stewart
Mk 1 Cooper S 1965
PostPosted: Sun Oct 08, 2023 9:01 pm
Thanks for the information and help, all fixed now.
Rgds Stewart
Mk 1 Cooper S 1965
Users browsing this forum: Pottsy and 80 guests
